Post new topic Reply to topic  [ 18 posts ]
 Post Posted: 24 Jan 2014, 08:07
Hey guys i actually purchased a cold air pipe last weekend and i now want to install it, i want to fit it in the section where the fog lights usually go - as i have a 1.4is there is no fog lights and it just has the covers in the fig lights place - i want to remove the driver side one to fit the pipe - how does one remove it ... do you have cut it out or is it a bracket that just needs to be clipped out from the inner section of the bumper??
HELP NEEDED LOL!!!!!!
 Post Posted: 24 Jan 2014, 08:08
It has to be cut out afaik
 Post Posted: 24 Jan 2014, 10:51
any easy way stanley knife or recommended to remove bumper?
 Post Posted: 24 Jan 2014, 11:01
Rather remove bumper, then cut
 Post Posted: 24 Jan 2014, 11:02
ok awsom i am going to try this weekend cant be that difficult to remove the bumper i hope
 Post Posted: 24 Jan 2014, 11:13
wouldn't recommend this tho, too low... water WILL get in there.
 Post Posted: 24 Jan 2014, 11:21
Your car dropped gasman?
if its a std corsa b, its very high
 Post Posted: 24 Jan 2014, 11:25
True, true...
 Post Posted: 24 Jan 2014, 11:33
The car is standard height has a set of 17's on aswell , looking to swop the 17,s tho have them on gumtree need it lower.
its actually not a complete pipe it is the flex pipe you get - the bending type one - just to help supply cooler air cuz since i pt the branch in the engine bay is alot warmer then before - also looking at heat wraping the branch in the future want the car to breath better you know
 Post Posted: 24 Jan 2014, 11:37
Rather get that branch powerkoted
Better than that heatwrap stuff imo
 Post Posted: 24 Jan 2014, 20:44
+1 :2thumbsup:
 Post Posted: 24 Jan 2014, 20:45
Rather take your head light out to fit it!! before u remove the bumper!!!
 Post Posted: 25 Jan 2014, 18:18
whats wrong with heatwrap? Some expensive builds have them.
 Post Posted: 29 Jan 2014, 14:15
WOW MAN THAT COLD AIR SETUP IS AMAZING!!!!!!
what did that set you back?
 Post Posted: 31 Jan 2014, 21:07
R850
 Post Posted: 07 Feb 2014, 12:07
You have to cut them out. I cut mine out, but then I realized it was a mistake, cause I now have a CAI setup and my filter sits at the bottom now and you can see it through the hole. Will probably have the covers plastic welded in again.
Daily: 2005 Corsa Lite
Jason Clifton Photography
 Post Posted: 07 Feb 2014, 16:58
Fit fogs if you cut them out. Might as well.
 Post Posted: 08 Feb 2014, 10:23
:2thumbsup:
