 Post Posted: 25 Jan 2021, 22:08
Hey Guys
Ok so i have a 1995 Opel Astra Estate 1.6i. That has major wiring problems and some other motor related issues.
I was "Lucky" enough to get hold of a Opel Astra 1.6 Echotec motor For Dirt cheap. Its a Opel astra G 1.6 16v Z16XE.
Now i want to transplant this motor into my old girl.
Questions i have is. The bellhousing on the 1.6 Echotec motor should take the 1.6i 8v gearbox of the Estate?
I am almost sure i will have to put a Diktator in to make the motor Work. Which one?
Then the motor came without Injectors. Will i be able to use my 8v injectors on the new motor ?
Will the motor fit to the Estates engine mounts ?
I need a outlet manifold for the motor does any one have a cheap one lying arround :P
Oh and i want to get some work done on the cams of the 16v motor. Do you think 284 would be to agressive ?
ok those are my Questions.
Oh and i got the motor for R3500
Thanks in advance :Help:
 Post Posted: 27 Jan 2021, 15:13
So Just an update. Gonna go with a Spitronics Orion2 Advanced as my ECU for the build.
Users browsing this forum: No registered users and 7 guests
