Post you DIY experience here or find out how to DIY
Roof Lining Astra F
30 Mar 2010, 07:57
I have every intension of doing this job myself but need to know if there are tricks do's and don't I have done it once before with a mate of mine and it worked out great on my GSI. Gonna get material @ Kehls and some contact glue anything else I might need?
Re: Roof Lining Astra F
30 Mar 2010, 08:10
That should be about it. Oh yes, please dont forget to take pics and to write a DIY coz I need to do my roof also. :ninja:
Good luck. :duim:
30 Mar 2010, 08:16
Will try to document!
30 Mar 2010, 09:53
SELWYN het syna gedoen vra hom dit het baie mooi uitgekom
30 Mar 2010, 12:27
TAUzty wrote:SELWYN het syna gedoen vra hom dit het baie mooi uitgekom
SELWYN what's the best way to loosen those two fasterner running down the middle of the roof dude. Should I just force with a screwdriver?
06 Apr 2010, 16:06
He's my experience
1.) Tools needed so far, Screw driver and Touque set.
2.) Remove head rests and lower seats
3.) Remove sun visor and all other fittings.
4.) I wedged out the fasterners in the middle of the roof using two flat screw drivers.
5.) loosen pannels with tourque screw driver.
6.) mark wires and remove interior light.
7.) I opted to cut the wires to the arlarm sensor
8.) It;s easy after this just pop out the ceiling and manouver it out the back door be carefull not crack the mould dont be impatient.
16 Apr 2010, 15:23
Nice :duim:
16 Apr 2010, 15:35
Will complete when I am done glueing down the new material and fitting.
16 Apr 2010, 16:01
Lester wrote:Will complete when I am done glueing down the new material and fitting.
put some corrugated cardboard inbetween the liner and the roof to reduce noise ;)
20 May 2010, 13:47
i must redo mine cos it got messed up at the back by the grab handles
14 Jun 2013, 14:36
Guys I have a question.
I got someone to do my roof lining but the idiot cut the wires to the light and never replaced it.
Where do i trace the wires from? so i can rerun the lines without having to take the lining out.
Edit: I cant take it back to him, guy resprayed my car and thats far from where i stay.
16 Jun 2013, 10:39
I soema used speaker box mat. Doesn't get dirty and very light.
viewtopic.php?f=12&t=19991&hilit=Roof+Lining
