Post you DIY experience here or find out how to DIY
Induction kit : Corsa Utiliy 1.8
19 Apr 2014, 09:37
Hi guys ,
Im looking to install an induction kit in my Corsa utiility 1.8
Can you please advise me as to what to do to get best results.
Re: Induction kit : Corsa Utiliy 1.8
22 Apr 2014, 08:38
Best results would be piping all the way to behind the spotlight. But it's still not better than std airbox. Just make sure that cone doesn't see water. 8O
Silicone reducer on intake into aluminium pipe going to where your airbox used to be, then 45 degree bend going to the front of the car, pointing down as much as it can, then another 45 degree bend pointing down so that the filter can sit somewhere behind the bumper. Usually behind the spot. It's going to be some figuring out using silicone attachments and aluminium pipe to get the setup to look best.
22 Apr 2014, 09:07
... or just 1 reducer and one bend and your cone ...
22 Apr 2014, 10:31
Klonkie wrote:... or just 1 reducer and one bend and your cone ...
Yes that's the usual one. You can buy the kit like that from most accessories shops :thumbup:
22 Apr 2014, 10:41
Thanks guys
I fitted the kit over the weekend but I noticed a whistling sound.When I put my foot down I get a whistling sound and when I take my foot off the accelerator.It seems to go away when I go over 3000rpm.
Any idea what could be causing that and how i can fix it ?
22 Apr 2014, 10:46
that's the cone filter LOLS
22 Apr 2014, 10:50
Lol I know what sound the filter makes , but it isn't sounding like it should . Sounds like there's air coming in somewhere where it isn't suppose to
22 Apr 2014, 11:03
Are you sure it's a whistling sound and not more of a Darth Vader sucking noise? If it's the latter then it's normal. Usually under very light throttle and at cold start when the car is cold.
Are all the tubes still fastened properly to the sensor that was attached to the back of the old filter box? I know when the middle one starts coming off it whistles and the revs are high at idle.
22 Apr 2014, 11:20
I know what sucking noise you taking about , but it's not that..
I've noticed my revs are higher at idle so I will check the tubes going into the sensor .
22 Apr 2014, 13:41
What's the make of the cone?
Similar thing happened on my buddy's ute - fitted the same contraption on mine and less of whistle and more of a ffrrrrpp. It's normal I thunk.
22 Apr 2014, 13:56
8v doesn't go any quicker on induction . . . . as I understand - just loud and more fuel being used 'cos you play with that make noise pedal more often
22 Apr 2014, 14:00
Mr Lupini wrote:8v doesn't go any quicker on induction . . . . as I understand - just loud and more fuel being used 'cos you play with that make noise pedal more often
+1
Having said that ... my kw reading at Dynotec was (at it's highest) 76kw ;) with only the cone filter fitted
Still love the sound.
Gorrel it down the main road!!
22 Apr 2014, 14:08
That sucking sound is normal :)
22 Apr 2014, 14:20
"Still love the sound.
Gorrel it down the main road!!"
+1 =D
22 Apr 2014, 14:45
what i did was keep my std box in the car but then i did some contraption and fitted a cone filter inside of it and it works great. Except when i open it, dan syp hy soos uh vis!
