Post you DIY experience here or find out how to DIY
opel zafira back door
05 Jul 2015, 14:45
Hi there. Havent been on here for a looooong time. Need some assistance please. The passenger backdoor of my wives Zafira I cant open. Central locking went on it but I could still opeN it mamanually.now the problem is the childlock is on and I cant open the door from inside or outside. Managed to get door panneling loose and get my arm in there. Took door handle off but not helping me at all. I cannot get door mechanism loose Or release it.Nou wat nou. Would like to fix it but cant get door open to unscrew mechanism/clip. Help asseblief. :PissedOff:
Re: opel zafira back door
06 Jul 2015, 08:12
Off the interwebs,
There is a plastic bung in the lower part of the inner door. Prise this off and use a long flat screwdriver to try and locate the lever and actuate it manually.
https://www.avforums.com/threads/zafira ... n.1750095/
06 Jul 2015, 10:47
Thank you Viper1350 . the problem is it's tha backdoor . I cannot get the door panneling off only partially and managed to get my arm in there to loosen the actual door handle and take it off and tried working through the doorhandle hole.
I managed to loosen the sgrews on the plastic doorlock mechanism but cannot get the plastic covering it off. Moeg gesukkel
06 Jul 2015, 11:10
hansie wrote:Thank you Viper1350 . the problem is it's tha backdoor . I cannot get the door panneling off only partially and managed to get my arm in there to loosen the actual door handle and take it off and tried working through the doorhandle hole.
I can only imagine. It could be something as simple as a fuse that's gone, but I'm assuming you've already checked that since you've removed paneling to try get to the actuator.
Unfortunately, I don't have any advice for you boet :thumbdown:
07 Jul 2015, 12:56
Thanks dude. Het al alles probeer
