Post you DIY experience here or find out how to DIY
Welsh plugs on a astra f seh20 how to remove them
05 Dec 2015, 21:06
Hi guys I'm sitting with abit of a problem I noticed my car was leaking water couldn't find the leak but by chance and a stream of water I found it to be at the back of the motor by the alternator and right by the knock senser both welsh plugs are leaking. My question is how do you remove them I can hardly get my hand in there I've used a temp salution (pratley steel) but I would really prefer to change them thanx
Re: Welsh plugs on a astra f seh20 how to remove them
07 Dec 2015, 05:51
Very crappy spot,u have to remove everything,alternator and rear water pipe,then with a use a hammer and screw driver to knock it on the one side till it pops
