Wayno
Posted: 20 Sep 2012, 12:38 |
Joined: 12 Apr 2009, 21:19 Posts: 1619 Location: Bellville
So as you know ive bought an astra f 160ie full house. As with most f series the interior fan resistor gives in,so has mine,i removed it and noticed its very rusted,which and this causes the termals to break off,so I check ok the inside should still be fine,grinded the spots where the termals was and solderd on my own(the yellow spade in the pic),then fitted it and oh hel it worked! If I new it would work I would of took step by step pics,sorry. Saved R575.50  . Rum money.
| Attachments: |
Posted: 20 Sep 2012, 12:43 |
can u make my heater work ? hahahah
TAUzty
Posted: 20 Sep 2012, 13:55 |
Joined: 19 Jun 2007, 10:49 Posts: 16181 Location: Detailing a ride
Wayno , please please I beg of you please can I bring my car around for you to sort that out please i have the same problem since I bought the car its needs a resistor.
I really need my interior fan to work
_________________ Race car : 200is Turbo 200.3kw and 405nm KILLER  . Family Car : E39 BMW 540i Individual 4.4 V8 Avus Blue 217kw and 460nm Stock Standard .
Wayno
Posted: 20 Sep 2012, 14:00 |
Take out your resistor then I will convert it for you. Its just 1 screw.
TAUzty
Posted: 20 Sep 2012, 15:23 |
ok cool will take it out the wkend thanks so much .
Posted: 20 Sep 2012, 16:42 |
I had to do the same thing, it is been working fine for 4 years already
Chez 200is
Posted: 21 Sep 2012, 10:53 |
| Filter, Exhaust & Branch |
Recently my fan stopped working between 1 and 3. Only works when it’s on level 4. And it works well but is this a sign that it’s on its last legs.
TAUzty
Posted: 21 Sep 2012, 11:31 |
F-series is not a normal opel LOL
Chez 200is
Posted: 21 Sep 2012, 11:41 |
TAUzty wrote: F-series is not a normal opel LOL Lol, Most of the gadgets actually still works in my car except for the AC which never worked since I bought it, and the rear window demister. And the fan only works on level 4. Other than that it seems ok. Ek dink my kar was op n maandag gebou.
sterlingesterhuizen
Posted: 22 Mar 2014, 08:06 |
| Cams, ITB's, Headjob, Management |
Joined: 09 Jul 2008, 11:59 Posts: 2991 Location: Kimberley
Mine us to work on all 4 then all of sudden not one of them worked. You guys think it could be something else then the resistor coz I see some of you guys still work on level 4
_________________ Hers:Opel Corsa Chill 1.3 His: Are you kidding me???? When married it states "What is yours is mine what is MINE is MINE!!!! Ours: Chevrolet Cruze 1.6L
Wayno
Posted: 22 Mar 2014, 08:20 |
Definately the resistor ms s
GFunk
Posted: 22 Mar 2014, 08:21 |
Guys essential tools required for us DIY guys: 1. Digital Multimeter ( Dont have to be fancy but Fluke meters real good). 2. Soldering iron (Gas soldering irons handy ) and soldering wire. 3. Handy stuff like wires resistors diodes for when u need it.
Now u can DIY or FIY(Fix it youself ) yourself just like Sterling.
_________________ _________________  ex: '90 Kadett GSI Sold ex: '96 Kadett 200is Write Off Current: '94 Opel Calibra 2.0 16V Weekend Tool '07 Opel Corsa UTE 1.4 sport Work Tool
sterlingesterhuizen
Posted: 22 Mar 2014, 12:10 |
Any idea on what type of size ohm resistors and diodes??
GFunk
Posted: 22 Mar 2014, 17:06 |
Brutjie resistors for LEDS is so 560 ohm - 2k7 ohms . For other stuff u can get equivalent value resistor of lets say 0.1 ohms to 1 ohm and boost up the wattage to 5 or 10 watt. Diodes 1n4007 diodes for general work up to 1 amp .For higher amps u can look at 1n5401 series or better.
sterlingesterhuizen
Posted: 23 Mar 2014, 18:25 |
Wayno I remember when I pull out the fuse for the fan at the fuse box and then I put it back in then the fan would makke the clicking sound. Do you think it would still be the resistor?
Posted: 23 Mar 2014, 20:08 |
if it is not working on 4 it is probably the fan motor, accepting the fuse and wiring is ok
wanx
Posted: 05 Jun 2014, 10:39 |
Hi Ouens help waar sit die ding voor ek strip
Posted: 05 Jun 2014, 11:29 |
Under the wipers
sterlingesterhuizen
Posted: 05 Jun 2014, 12:03 |
Wayno when are you gonna do a proper DIY for us?
wanx
Posted: 05 Jun 2014, 16:33 |
Thanx G gona check tonight if the weather calms a bit
