 Post Posted: 07 Aug 2013, 13:02
Hi guys,
So after doing some research on how to restore your headlights and having the guts to do it myself, so i came across a couple of clips on youtube ect...that was really useful and I must say I was surprised.
FYI I'm no professional, anyone can do this
What you will need is the following:
A bucket of soapy water ( I used Sunlight liquid)
600 grit wet sand paper
800 grit
2000 grit
and good headlight polish or cutting cream, I used Autosol Metal Polish :winkithumbs:
I did a small section just to be on the safe side.
So starting with 600 grit dip in soapy water and start sanding the headlight in one direction and apply a bit pressure not too much though until you see that soapy water becomes a bit dirty then you know for sure that you getting somewhere so just a couple of strokes , ( you know you get mense with mal krag)
do the same process with the 800 grit afterwards and then when you start using 2000 grit you will notice some change in your light when you do, then try and sand in a circular motion because you now feel that the surface of the lense becomes smoother, so for the final step you will need your cutting cream or good polish, wipe headlight clean with some rag until its no longer wet ect... so now you apply your polish with an applier or any microfibre cloth and start rubbing until the layer of polish becomes thin until you see some change and for final step take another clean microfibre cloth buff until you feel that silky smooth surface and vwaaLA!! i will attach a before and after of how my headlights look.
Ex cars: 1st. 1974 VW beetle
2nd Opel Kadett 1.6 GSE
3rd Opel Kadett 1.8 8v GSi
4th Opel Kadett 2l 8v GSi (red)
5th OPel Kadett 2l 8v GSi (black)
6th Opel Astra 1.6 CDE
Current car: 2003 Astra Coupe Turbo
 Post Posted: 07 Aug 2013, 13:56
:clap:
Impressive, well done
 Post Posted: 07 Aug 2013, 14:08
mooi man
 Post Posted: 07 Aug 2013, 15:23
Did you purposely miss the clips that recommended the use of toothpaste?
 Post Posted: 07 Aug 2013, 20:31
The toothpaste don't work. I tried it and it came out worse... But i think I just messed up.
 Post Posted: 08 Aug 2013, 08:10
:winkithumbs: Thanks Gents, lol about the toothpaste yor i tried 3 different kinds like the sensodyne,colgate and aquafresh but didnt work, my Mom even gave up on me and these headlights and told me " Heay go to a place where they do these things and rather pay" but I would rather save money where I can.
 Post Posted: 08 Aug 2013, 09:42
Apparently the whitening ones or the extra minty ones work best? Still sounds too good to be true
Good job man!
 Post Posted: 08 Aug 2013, 10:07
i used toothpaste and vaseline once on a laptop screen
'06 Astra H GSi 2.0 Turbo
'79 Datsun 160y GX Coupe
'95 200 GXi SR20VE 6spd
'92 200sx RB25DET
'06 Opel Zafira 1.8 Enjoy Panoramic
'01 200 STI sr20de
'93 S13 200sx RB25Det
'97 200iE 16v Astra
'71 Datsun 1600 SSS 2.0L
180is Opel Kadett 2.0L
Mk1 Golf GT 2.0 16v
 Post Posted: 08 Aug 2013, 11:56
Nice theres lot of easy roots .
I do this almost every weekend.
 Post Posted: 08 Aug 2013, 12:23
:) Yes sure there is,
 Post Posted: 11 Aug 2013, 13:32
very awesome! i will def try this out on my spare headlights looks great!
1992 Opel Calibra
2012 Hyundai i30
Ex
200ie
 Post Posted: 12 Aug 2013, 13:36
:winkithumbs:
