HOW TO Remove rear door cards
I could not find a decent guide with pictures so this is my "HOW TO", hope it helps.
NOTE: You must remove the rear seats first, and i'm not responsible for any damage you may cause. Take care and take your time.
1) Prise out the "AIRBAG" plastic clip on the B pillar
http://s936.photobucket.com/user/VXTRAY ... 5.jpg.html2) Lift the cover on the seat belt buckle and undo this bolt
http://s936.photobucket.com/user/VXTRAY ... 6.jpg.html3) Get your fingers under the rubber seal and pull the B pillar off towards you, this will reveal a bolt
http://s936.photobucket.com/user/VXTRAY ... 3.jpg.html4) Undo this bolt at the bottom towards the boot
http://s936.photobucket.com/user/VXTRAY ... 2.jpg.html5) Prise this little plastic cover off located at the bottom towards the front with a flat end screw driver and undo the bolt behind it
http://s936.photobucket.com/user/VXTRAY ... 4.jpg.html6) Undo this bolt located at the bottom which holds the front seat belt
http://s936.photobucket.com/user/VXTRAY ... 8.jpg.html7) Now all bolts are undone the only thing holding it on is the clips. I started pulling the card from the top towards the back of the rear window and then worked my way across until in was all unclipped
http://s936.photobucket.com/user/VXTRAY ... 7.jpg.html As you start to pull it away from the car, remember to remove the other side of the piece of steel that holds the front seat belts in, its not bolted in, it just hooks into the car and is a little fiddly to pull out. Once thats out the whole card can be taken out
http://s936.photobucket.com/user/VXTRAY ... 1.jpg.html
