Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: Monoblock problem
 Post Posted: 02 Sep 2012, 21:15
I need advice on my sound
I have 2 Dvc 12 subs running off a 4000watt Ice Power Mono.
1st my fuse (40watt) that's on live wire at batt that supply the amp popped. I then put in a 60watt and it popped again.
I then but in a blade fuse 175wat and it didn't blow but now my amp cuts out and the red protection light goes on. When I put front loader off and then on again the amp is playing put as soon as I put volume on 20 ( and front loader can go to 60) then amps go off and red protection light goes on. I did check all the wiring and also found no burn smell coming from amp.
I need advice. Thanks.
His
2003 Astra G 2l 16v
Hers
2009 Yaris T1
http://i1071.photobucket.com/albums/u51 ... 17377a.jpg
 Post subject: Re: Monoblock problem
 Post Posted: 03 Sep 2012, 07:58
it sounds more like there is either too much current running through to your amp, but that shouldn't be the situation, as you have a amplifier kit installed. I would check the amp & it's fuses. See whether the fuse is not faulty at the amp. This might be the problem.
 Post Posted: 03 Sep 2012, 08:08
Never replace a fuse with one with a bigger rating! Sure way to melt wiring!
.\X/.killa
2001 E39 530d
1987 E30 325i (RB25DET)
 Post Posted: 03 Sep 2012, 08:10
 Post Posted: 03 Sep 2012, 11:03
I did check the fuse with the test light and evrything ok. I tried to play only the one sub from amp but still get same results. If you say to much current to amp - what must I do 2 reduce it.
His
2003 Astra G 2l 16v
Hers
2009 Yaris T1
 Post Posted: 03 Sep 2012, 11:47
Howzit Shamiel :duim: , Is the CSX still going nicely? Sorry to hear about the amp problems. Ask someone to take out all the existing wires and replace them with new wires.
I found a website which show your different size wires to use for the specific RMS your amp puts out or power your speakers can take.
http://www.the12volt.com/info/recwirsz.asp
Good luck Brother.
 Post Posted: 03 Sep 2012, 12:41
correct... dont go bigger than the size they recommend for the amp.
also how do you have the subs wired to the amp? i think that it might be the way your subs are wired.
give the specs of the subs as well as the amp... more specifically the ohms. i think you might be overloading your amp hence it going into protection.
don't try playing the volume higher unless you want to say goodbye to the amp. first have someone check it out for you.
 Post Posted: 03 Sep 2012, 13:15
Hi Cheslyn, CSX still going strong. Did you buy that CSX?
That site is very helpful will compare that info tonight.
8valve thanks for the adviCe. I have Ice power 4000watt monoblock class D. The subs is 1400watt champion series pioneer subs, have to open the box to check the omhs. I did the installation my self. Have live from batt and remote wire from deck. I wired each sub on one channel. I am thinking of replacing all the cabling this weekend as I do have spare set amp kit. What can I still do.
His
2003 Astra G 2l 16v
Hers
2009 Yaris T1
 Post Posted: 03 Sep 2012, 13:18
The amp has two channels and I dedicated one sub per channel.
His
2003 Astra G 2l 16v
Hers
2009 Yaris T1
 Post Posted: 03 Sep 2012, 14:29
you need to see the ohms the amp can handle and wire your subs to match what the amp can handle.
i'm going to post a few wiring diagrams just to give you an idea of what you should be doing.
if possible maybe post the models of your subs and amp. that way we can google the specs and give you an idea of how your subs should be wired
 Post Posted: 03 Sep 2012, 15:13
 Post Posted: 03 Sep 2012, 15:27
oh yes i only used 4ohm as examples because those are the subs i had.
for your subs you would obviously use different diagrams depending on your subs and amp.
the diagrams can also be found on the 12volt link posted by cheslyn
 Post Posted: 03 Sep 2012, 20:38
Thanks 8valve for the advice. I come home late tonight and will take out the subs 2mor and give u all the data.
Thanks.
His
2003 Astra G 2l 16v
Hers
2009 Yaris T1
 Post Posted: 03 Sep 2012, 21:39
Dit my gepla toe gaan krap ek ma. All this info was on the amp and subs.
Subs
Pioneer - TS-W307D4
1200w max
400 NOM
4ohms DVC
Amplifier
Ice Power - PS4000D
Pro-series amplifiers
Class D
Mono channel
Digital circuitry
Max 4000watts
This on left side of amp
1. Line input - (RCA)
2. Red bulb - Thermal. Prot
3. White bulb - Power and Prot
4. Level (control knob)
5. LFP (control knob)
6. Bass boost (control knob)
7. Phase shift (control knob)
8. Remote (plug)
9. Line out (RCA)
Right side of amp
1. Earth wire
2. Remote wire
3. Live wire
4. 4 fuses (30amp each)
5. 2 channels for subs
Before my amp cuts out then the white bulb is green. When it cuts out then white bulb turns orange.
My set is as follow.
Each Sub is connected seperated to one channel. - positive connect to positive on sub and then to amp positive. The same with the neg.
Hope u can now advice me with this info.
His
2003 Astra G 2l 16v
Hers
2009 Yaris T1
 Post Posted: 04 Sep 2012, 08:15
Subs
Pioneer - TS-W307D4
1200w max
400 NOM
4ohms DVC
Amplifier
Ice Power - PS4000D
Class D
Mono channel
Digital circuitry
Max 4000watts
8. Remote (plug)
9. Line out (RCA)
Right side of amp
1. Earth wire
2. Remote wire
3. Live wire
ok your amp can handle 1ohm. so the 1st diagram should be fine. and you should be using a 120amp fuse.
is that a new amp you using?
 Post Posted: 04 Sep 2012, 08:53
Hi Shamiel
i think i know where your problem is. Where are you from. PM me. Is this the amp you using (one on the left). If it is..I have the same amp as you can see
 Post Posted: 04 Sep 2012, 11:25
No its a second hand one. My setup is like diagram 1 only diff is that each sub is on a channel as I have two channels. So I will try and bridge the channels as per diagram.
Thanks buddie.
His
2003 Astra G 2l 16v
Hers
2009 Yaris T1
 Post Posted: 04 Sep 2012, 11:43
your setup is fine. inside the amp it goes to one channel so don't change anything.
check with Igshaan or if you close to woodstock you can come around to my place after working hours to check it out.
i have a feeling it's the amp thats not 100%.
 Post Posted: 04 Sep 2012, 13:13
I am very much sure that its in the wiring of your speakers. Check that out first before you do anything else. If there is nothing wrong with the amp then your next step is to check the wiring. Remove the subs out of the box and see if the positive is on positive and vice versa. If you have a positive (on the sub) connected to a negative on the amp then it will work and play. but the moment you increase the volume your amp will cut out as the load is wrong.
I have been running that amp for years and never had a problem with it. Thats my second 4000W im using. Sold the other one. And im running 2X XTC 2500 subs on the amp on 1ohm stable. And believe it or not. i am not running a fuse. For all these years I never ran with a fuse. in the pic you can see the 200A digital fuse in the middle but it's not connected. And that is a great amp. not the best of amps but it can take a load :silent: ..........
let me us know the outcome.
 Post Posted: 04 Sep 2012, 15:43
correct those amps are die hard and they can really take a punch. the newer ice power amps don't compare to them.
my bro used to run 2 triangle subs from his as well and it never gave problems.
if i didn't have the rockford amp i would probably have been on the hunt for one of those :duim:
