SavageScorpio
Posted: 03 Jun 2013, 16:36 |
Joined: 20 Mar 2013, 11:13 Posts: 30 Location: Northen Suburbs
Is there anyone who has one of these Jensen dvd players in there car? I need help with the following. -How do I override the parking brake so that the dvd player can play while the car is driving and not only when the handbrake is up.(not sure of the law on this) -My memory keeps resetting when I turn off the ignition. How do I fix that? -The player is currently only working with the ignition on, so how do I get it to work without the ignition? Any help will be appreciated.
| Attachments: |
Darth Vader
Posted: 04 Jun 2013, 09:10 |
Joined: 13 Feb 2013, 10:19 Posts: 792 Location: Rondebosch East
check the remote wire
-The player is currently only working with the ignition on, so how do I get it to work without the ignition? Keep it like that rather,cos leaving ur car and forgetting to switch ur deck off is gona give u a hard time.
and to answer ur first question,theres a cable that needs to be unplugged for the screen to play while driving..i cant remember what one it is tho..
_________________ victory consistantly,train all year to be the enemies misery
WayneCD
Posted: 04 Jun 2013, 09:20 |
| Upgraded to a Flatbed Filter |
check the remote wire Wrong, the remote wire is for amp power only, connect yellow and red wires together to the power source of the car(battery), this will keep memory
Darth Vader
Posted: 04 Jun 2013, 09:33 |
lol my bad,,,forgot to metion that aswell...my remote wire was connected wrong which affected my memory.
Posted: 04 Jun 2013, 10:55 |
WayneCD wrote: -My memory keeps resetting when I turn off the ignition. How do I fix that?
check the remote wire Wrong, the remote wire is for amp power only, connect yellow and red wires together to the power source of the car(battery), this will keep memory Deck will also work with ignition off then.
Posted: 04 Jun 2013, 11:15 |
so basically Dv's memory is messed up '? LOLS
Darth Vader
Posted: 04 Jun 2013, 11:40 |
aweeeeeeeeeee
Tino
Posted: 04 Jun 2013, 11:42 |
Joined: 04 Jul 2007, 15:02 Posts: 6250 Location: The Chuck's Hideout
I think the brown wire goes to the handbrake lever. Just check to make sure what color it is. That wire must be earthed for the DVD to play while driving. Illegal AFAIK.
_________________ .\X/.killa
2001 E39 530d 1987 E30 325i (RB25DET)
SavageScorpio
Posted: 04 Jun 2013, 18:08 |
Thank you for the help so far guys...I attached a piece of flex wire to the parking line and it accidently touched the body of the car so I earthed it and now my videos can play while I drive, so that is sorted. As for the other solutions I will try to do what you guys said this weekend hopefully if I get some time.
8 Valves of glory
Posted: 06 Jun 2013, 12:51 |
| Cams, ITB's, Headjob, Management |
Joined: 18 Jul 2008, 12:15 Posts: 3914 Location: Lost
wayne and tino spot on.
_________________ Current: 98 Ballade 180i EX: Monza CD16V Ex: GSI Boss 8 valve
