Spike OPC wrote:
I had no idea about that, so for optimum power ill need to get new RCA's fitted because these RCA's split into dual RCA's each for the 4 channel
Honestly speaking, i doubt it will make much of a diff if you connect the RCA's to your 4CH first and then to your Mono....
You should try and test it for your self, connect it first to the 4ch amp and then to the mono, listen to a a heavy bass song....
then Connect it the other way around and hear it... all AMPS are different so you will most prob have to see and hear for your self which method works for your setup
