 Post subject: Corsa C radio wiring
 Post Posted: 17 Oct 2013, 11:12
good morning peeps
i installed my single DIN Sony head unit in the Corsa last week and had an issue with the wiring. i currently don't have FM radio as the aerial plug doesn't fit
I'm looking for a wiring loom connector for the Sony deck as this will neaten up the wiring, and sort out the radio issue
please let me know where i can find a connector for the Corsa C (CPT Northern subs) similar to this:
thanks!
'09 Opel Corsa Utility 1.4 Club
 Post subject: Re: Corsa C radio wiring
 Post Posted: 21 Oct 2013, 11:13
Didn't your sony deck come with an ISO adapter which plugs directly into the factory wiring plugs? Then all you have to get is an aerial adapter by Soundmatch or Zakspeed in Goodwood. Its about R20-50 for the adapter. Soundmatch should sell those wiring looms as well if you didn't get one with your deck.
