Goku2000
Posted: 25 Nov 2013, 13:22 |
| Opel Club Cape Town PR & MARKETING |
So I am planing to install some sound stuffs to the Calirbra. Amp, 10" sub and split mids.
Now i have install an amp and sub before and did it pretty well ( if I say so myself). But I was thinking is it difficult to do the install of the split mids? I have no idea where to even begin.
So is it something I can do myself or am I better off taking to a sound place to do the install.
* Note the sub and amp install was on a mk1 golf so the panels are pretty easy to remove lol
_________________ ex: '04 Alfa Romeo 147 2.0 selespeed ex: '87 Golf mk1 cabriolet ex: '95 Opel Calibra 2.0 16V  Current: '06 Opel Astra H 2.0 T :Astra
Posted: 25 Nov 2013, 17:50 |
The only issue you are going to have getting aftermarket thicker wires through to the doors (making it look neat it mean), but this is only if they used the same rubber sleeve they do on the F's
Depending on the depth of the speakers the window can become an issue when rolled down. Mine just just misses
Goku2000
Posted: 25 Nov 2013, 20:10 |
Thanks man. I'm gonna give it a shot. Doesn't look to hard.
Vitesh
Posted: 26 Nov 2013, 11:55 |
Joined: 06 Oct 2011, 16:04 Posts: 669 Location: Cape Town
Yo
Basically 5 things to look at which will help u decide if u wanna do it yr self or not lol...
1. Wiring from the deck to an amp and then back to the speakers can get tacky, thats if you're going to power your Speakers with an amp. If your deck has no "low volume" output you will need to purchase a high-low converter (if using amp). check if you have enough cable to route all the way to your boot from the deck .(where the amp would be) . If you not using a AMP, then its pretty straight forward with just replacing the speakers in your doors...
2. Removing door panels can get annoying. you will have to pull your deck out and possibly the floor sill panels to hide your wires to the amp.
3. The size (diameter) of your mids may not be the correct size to fit in your door, unless you have properly researched the size to get. after getting the correct diameter, you must pray that the depth of the speaker does not interfere with your window mechanisms.
4. If you just fitting mids then step 3 was your last of worries,,, lol,,, if you're fitting a split system then you need to locate an appropriate place to keep the cross over network unit. then locate a place for the vocal tweeter and wire it to the cross over unit.
5. After all connections done and tested, you will have to close and seal all opened door and floor sill panels. tuck all excess wiring away, ensure wires are insulated and secure behind deck
then sit back relax and know its done,,,, fo freee! lol
_________________ ____________________________________
2010 Corsa D 1.6 119Kw Turbo Sport 2010 Corsa D 1.4 Sport 80kw
Posted: 26 Nov 2013, 12:01 |
we'll come watch you do it - smoke a pyp and have a 6 pack
Vitesh
Posted: 26 Nov 2013, 12:15 |
Mr Lupini wrote: we'll come watch you do it - smoke a pyp and have a 6 pack Ha ha ha good 1 Lupini, can watch him puzzle whilst we
Goku2000
Posted: 26 Nov 2013, 12:22 |
Vitesh wrote: Yo
then sit back relax and know its done,,,, fo freee! lol Lol I was waiting for you Vitesh (the sound guy). So I will be running it to an amp, I am not sure if the deck has low volume output(will check). The calibra has tweeters in the doors so I want to put the new tweeters in there. (will be putting in split mids) I have checked and the calibra door fits a 6 1/2" mid. BTW you dont perhaps do installs? ( How much you charge) hahahhahahahahah
Posted: 26 Nov 2013, 12:27 |
Goku2000 wrote: Vitesh wrote: Yo
then sit back relax and know its done,,,, fo freee! lol Lol I was waiting for you Vitesh (the sound guy). So I will be running it to an amp, I am not sure if the deck has low volume output(will check). The calibra has tweeters in the doors so I want to put the new tweeters in there. (will be putting in split mids) I have checked and the calibra door fits a 6 1/2" mid. BTW you dont perhaps do installs? ( How much you charge) hahahhahahahahah You need to check how deep the magnet is, to make sure your window clears the magnet.
Goku2000
Posted: 26 Nov 2013, 13:17 |
The speakers look very far from the window on the calibra but i will make sure to check.
Goku2000
Posted: 26 Nov 2013, 14:23 |
 Vetish I just realized I have no idea how to check if it has a low end out put? How do I check. Getting a little nervous to do the install now lol
Toy
Posted: 26 Nov 2013, 14:28 |
Joined: 22 Aug 2007, 01:30 Posts: 7994 Location: Afghanistan
_________________ "...And I'm not frightened of dying, anytime will do, i don't mind... Why should i be afraid of dying, there's no reason for it you've gotta go sometime..." Pink Floyd - Great Gig In The Sky  ex: '98 130i Snoek Bakkie ex: '04 Fiat Stilo 1.6 16V ex: '04 Mini Cooper S Current: Renault Clio 4 - 0.9 Tce  97 Uno Turbo
Goku2000
Toy wrote: :facepalm: Scumbag!!!! lol
Vitesh
Posted: 26 Nov 2013, 14:57 |
ha ha ha ,,, jeepers!
i can refer u to my sound guy lol. he will make anything work and is not bad for price His name is Sharlin 084 447 6897
I do/did installs, but i wont lie to ya, its a tacky job, thats y i found this dude, who is ever ready to turn your confusion into a solution
to check if your deck has "low level"/pre amp level output, simply check to see if it has output RCA's at the back.
You will find this easy on after market decks, not much on standard OEM decks.
OEM decks with out RCA outputs will require the converter.
Goku2000
Posted: 26 Nov 2013, 15:05 |
Oh yes it does have out put RCA's hahahhahahahah. ( you coming here with your fancy terminology!, low level? I was like wtf?) I will give him a call Thanks bro, coz need my sub installed plus the mids
Vitesh
Posted: 26 Nov 2013, 15:22 |
lol, low level is the same as pre amp level.... when using an amplifier, the signal input needs to "unamplified" from the deck already...
Yup, give him a call, he will sort u out, he is situated in parow north. If anyone needs help wit sound installs, boxes etc, yal can go to him
Posted: 27 Nov 2013, 15:33 |
im so gonmna enjoy watching him install . . . . .sit there and go "no no not that way " hahaha like mentioned said - check the diameter of the dr mounter speakers to ensure it clears when the window is rolled down - that will be the problem - rest is abc wiring  just labour
Goku2000
Posted: 27 Nov 2013, 15:42 |
Hahahahah Big up's to Vitesh! Called Sharlin yesterday, very helpful. Give great advice. His quote was very very very good. So will be taking my car to him sometime next week.
Vitesh
Posted: 27 Nov 2013, 16:01 |
Vitesh
Posted: 27 Nov 2013, 16:02 |
Sorry Lupi u wont get to see him puzzle now
Posted: 27 Nov 2013, 17:44 |
Sigh hahahaha
