As the title suggests
central locking*RESOLVED*
03 Apr 2012, 16:02
im having a issue with my central locking on my corsa c UTE, its only on the left door the knob pops up when i open it but if i press the button to lock the door only the drivers side locks and the passenger side stays open and i have to manually push it down which i usually forget to do when i lock my car. is this something major or can it be fixed quick and easy?
Re: central locking
07 Apr 2012, 05:03
..howzit bru, did you ever get this problem sorted out?...and did the ride come out with central locking or is it an aftermarket mod?
Re: central locking
07 Apr 2012, 15:29
=BLAZER= wrote:..howzit bru, did you ever get this problem sorted out?...and did the ride come out with central locking or is it an aftermarket mod?
Hi, I never got it sorted yet I'm going to check it out tomorrow to see if there's anything obvious, it's aftermarket central locking from auto watch
Re: central locking
07 Apr 2012, 17:17
try little q20 alot of dust acumiloates in do0ors
Re: central locking
15 Apr 2012, 10:53
Who fitted the central locking?
Re: central locking
16 Apr 2012, 14:03
when i bought the UTE it was fitted already
Re: central locking
16 Apr 2012, 15:16
sounds like you need to replace the pump, or maybe the alignment of the bit of steel rod to the pump needs to be adjusted.
Re: central locking
19 Apr 2012, 10:07
Like Ghostrider said, check the alignment of the steel rod, I had the same issue on the Kadett and i just adjusted the steel rod.
Re: central locking
19 Apr 2012, 10:10
ok cool thanks guys, havent had time to do anything yet been very hectic at work. hopefully will get a chance when im home Monday
Re: central locking
08 Jun 2012, 16:07
Im having the same problem on my Kadett, you just need to tighten the clamp on the rod. I think the problem occurs once you start unlocking manually
Re: central locking
08 Jun 2012, 20:40
Autowatch uses a master and a slave actuator, sometimes the slaves break but they can be replaced. We sell them separately where I work. If you check it out and need parts just drop me a PM.
Re: central locking
12 Jun 2012, 08:31
i finally had some free time last night to check what was going on, the arm that goes onto the motor was loose (1 of the screws fell out some how) so it came off the pin of the door knob, i just made it as tight as i could until i can get one of those small screws...its all working fine now....thanks everybody for the help and suggestions you all offered :duim:
