 Post Posted: 09 Jan 2013, 11:37
Hi Guys...
I need help!!! My fan knob on my centre consol, on my corsa B turns from 0-4..... But no air comes through the vents. Could it be, that there is a failed connection somewhere or could it have to do with the aircon??
Then..... When arming & dis-arming my alarm, only the left hand side indicator lights flash but not the right side. But when driving, indicating to the right the lights work as per normal.....
Is there any way these two issues can be fixed!!
Thanx
J-Gsi
 Post Posted: 31 Jan 2013, 13:25
check fuse number 15 in the fuse box. should be the big green 30amp fuse.. :duim:
CURRENT RIDE: 97 PRE FACELIFT CORSA LITE STILL UNDER CONSTRUCTION
 Post Posted: 31 Jan 2013, 20:19
The fan is probably your fan resistor thats blown, happens a lot on the astra F series.
And the alarm indicator issue might just be a loose connection or its not connected to the hazzards but only to the 1 flicker.
2005 Honda Accord Type S - K24A3 - 122WKW 200Nm @ JDM Worx
1997 Corsa B X20XEV
EX - 2003 Ph3.5 Astra Coupe - 210KW 437Nm
- 17/02/2011 @ KSD
 Post Posted: 31 Jan 2013, 20:50
Hey Gents
Thanks for the assistance.....
Where about would the alarm module or casing be, to check the connection??
