Board index » General Chat » Advertise your services
Post new topic Reply to topic  [ 13 posts ]
 Post Posted: 20 Aug 2013, 13:47
Howzit gents below are some of the services im offering so PM/Call/email me for special pricing :2thumbsup:
FREE SERVICES :
Valve seat vacuum checking (for leaking valves and seats)
Cylinder head warp (for heads that have been overheated and have warped/bent)
Recon Services
Skimming (using PCD insert)
pressure testing (Hot & Cold)
Chemical dip ( heads, complete carbs, blocked tappet covers, intake etc etc)
Cutting valve seats ( performance 3 angle)
refacing valves ( aswell as backcutting for performance applications)
shimming
cylinder head straightening ( a must for severely warped heads to avoid a snapped camshaft!)
welding up cracked heads and various welding repairs
etc
etc
Performance Services
throttle body boring (TB is bored bigger and fitted with new brass butterfly)
Tapering valve guides ( for increased air flow!)
Flywheel lightening ( increased acceleration etc)
Custom steel flywheels ( demanding applications like Drag or track etc)
piston pocketing ( for bigger valves, heavily skimmed heads, wilder camshafts etc)
larger combustion chambers ( good mod if done in conjunction with reworking/modifiying chambers)
welding up combustion chamber squish pads ( better squish and more compression)
welding up injector bosses ( throttle body application)
intake manifold porting ( from a casting cleanup to full out porting involving cutting open plenum and reworking intake runner shape to desired size and application)
porting and polishing/ gasflowing all 4 stroke cylinder heads ( drag, track and street)
28" Flowbench developed intake and exhaust ports and combustion chambers (coming soon!!!)
Intake and exhaust manifolds developed using the latest racing PC sotware (coming soon!!!)
thanks!!!!!
Lee 071 4741314 / lee@lzaengineering.com
http://WWW.LZAENGINEERING.COM
 Post Posted: 20 Aug 2013, 14:07
Nice 8)
Welcome to the forum
 Post Posted: 20 Aug 2013, 14:09
Finally a place with a flowbench will keep your details awesome !
 Post Posted: 20 Aug 2013, 14:43
thanks guys :2thumbsup:
Tauzty we dont have the bench yet but will be building a proper 28" bench soon.
ill keep you posted.
thanks
 Post Posted: 20 Aug 2013, 14:50
How much would it cost for porting and gasflowing
My Ride:
94 Kadett 200tS Under construction
07 Corsa UTE
 Post Posted: 20 Aug 2013, 15:05
hey gumption it all depends on what cylinder head you have and to what extent you would like to go?
i can do normal porting/gasflow which is good for most people and applications and
we can also develop a intake and exhaust port for you by welding up and epoxying the ports and reworking them completely...
PM details on which kind of head and what you want done/application etc then i can give you a price.
thanks
 Post Posted: 21 Aug 2013, 11:56
location ?
 Post Posted: 21 Aug 2013, 12:23
as per their website
Physical Address:
31 7th Ave
Kensington
Maitland
7405
Cape Town
Contact details:
Email: lee@lzaengineering.com
Cell: 071 474 1314
Email: zee@lzaengineering.com
Tell: Zee 0834016201
 Post Posted: 21 Aug 2013, 12:27
Thanks CA!
 Post Posted: 21 Aug 2013, 12:36
LZA Engineering wrote:
Thanks CA!
:winkithumbs:
 Post Posted: 21 Aug 2013, 13:44
:highfive:
 Post Posted: 21 Aug 2013, 14:23
great stuff will hear from me soon :winkithumbs:
Current 97' Daewoo cielo(under construction)
Current 89' Opel kadett GSI 2L 8V
 Post Posted: 21 Aug 2013, 14:31
no prob buddy im running specials on:
Skimming
hot&cold pressure testing
chemical dipping/high pressure cleaning
street porting/gasflowing
we also have a pickup and drop off service!
thanks
