Any mod project you would like to share (performance, sound, styling, etc.)
2L 8V UTE Corsa B
13 Jan 2014, 14:45
Hi Guys
So finally the time has come for me to start with my conversion of going from 1.6 to 2L.
First I would like to :2thumbsup: Wayne Nortje for supplying with most of the things I will need to do the conversion
List of what I have thus far:
complete SEH motor
f18 gearbox
200is break calipers
shafts
200is loom and computer box
PROGRESS:
Motor is stripped as I am going to do everything over. I want to go bigger pistons and work the head.
I have a set of m3 e36 pistons(think its 86mm) that I want to fit. What are your guys take on this being done with a headjob? I will be using the corsa as a every day drive.
Will upload pics as I go along but I have a problem with resizing the pics.
Input and advice will be greatly appreciated
Thanx
:Germanflag:
Re: 2L 8V UTE Corsa B
13 Jan 2014, 16:09
Buddy 2.0 8v Stock is 86mm pistons !
13 Jan 2014, 18:11
Thanx for the heads up. So it will just up the compression then?
13 Jan 2014, 18:21
UTElover wrote:Thanx for the heads up. So it will just up the compression then?
depends on how they look. might also need to be machined to fit and possibly also pocketted.
13 Jan 2014, 19:33
Shot. So it will work if its done properly by the engineers
13 Jan 2014, 20:51
Very nice
Best of luck with the project :thumbup:
13 Jan 2014, 21:46
Ja. They might charge u a bit if they dont already have an example. But speak to the engineers and hear.
14 Jan 2014, 00:26
Thanx CA
Thanx Dean ill have a talk with the engineer. Will be looking at finishing it with in the next 3 months cause I want it to be as neat as possible
14 Jan 2014, 01:00
UTElover wrote:Thanx CA
Pls boet. Warren at bse is good.
14 Jan 2014, 09:12
Ok what is your aim .
just fit XE pistons to the car or leave the stock SEH pistons they have a smaller pocket.
if you want compression to raise you will need to deck the block and head atleast 1mm off head and 1mm of the block . Dont still go treading with bmw setup in a 8v.
8v are tough motors dont need much things to get them hauling .
14 Jan 2014, 13:54
My aim is to get decent power out of it for now as I want to throttle it at a later stage. Ill scrap the m3 piston idea then and look for xe pistons. Thanx alot for the help thus far..much appreciated. Also can I do the bteak upgrade in the mean time on the ute while a hunt around for the rest of the stuff?
14 Jan 2014, 14:50
Ok you will need to change your sideshafts for that engine to work . you cant use your corsa sideshafts.
No need hunting for xe pistons you can go to alert or masterparts and ask for stock c20xe pistons and dont buy the expensive one no point.
I and a couple of other much higher powered then me have been running cheap AUTOPOWER pistons for over 5years .
My pistons costed me R750 for the set they been through sides,itbs and 2turbo conversions .
go to alert they should have a set for you .
Deck the block while the motor is out and take a bit off the head.
Not sure what you mean BTEAK?
14 Jan 2014, 15:29
why not just fit a 2.0 8v?
or am i reading wrong?
14 Jan 2014, 15:35
He is fitting a 2lt 8v motor
bteak upgrade = break upgrade, tauzty
lol
14 Jan 2014, 15:41
why would you want to use the same oil pump with a maguyver mover instead of using a new pump? I dont understand that logik.
14 Jan 2014, 15:44
oh f*k im reading k*k, LOL
14 Jan 2014, 17:21
I have sideshafts for the conversion. Thanx for the correction CA. Ill get a set from them then thanx Tauzty. So with the xe pistons and a headjob and deck the block ill get decent power to have fun with Some of the vtecs and DE's
16 Jan 2014, 14:27
http://i928.photobucket.com/albums/ad12 ... eae2d7.jpg
http://i928.photobucket.com/albums/ad12 ... 95d089.jpg
http://i928.photobucket.com/albums/ad12 ... 7cd9f7.jpg
http://i928.photobucket.com/albums/ad12 ... 85e1c1.jpg
http://i928.photobucket.com/albums/ad12 ... c67408.jpg
16 Jan 2014, 15:52
You welcome :winkithumbs:
In photobucket where it says links to share just click on the IMG copy and paste it into the thread and post.
It will look like the above once you submitted the post.
16 Jan 2014, 18:34
Thanx buddy now I know for a next time. Seeing that you helped me with this you are more than welcome to help pay to finish the conversion lol
