Pantera
Posted: 06 Sep 2012, 02:42 |
Starting my 2L 16V high comp N/A build Current Parts list: Sub assembly:2L 8V block 2L 8V crank (mild knife edge) Scat Steel H-Beam Conrods Arp 2000 conrod bolts Wossner Forged High comp pistons Arp main cap studs GM oil pump with SBD steel inner gear Aluminium sleeved cambelt rollers Custom cam belt roller setup Cometic MLS head gasket Arp Head studs Arp Flywheel bolts Cylinder HeadPorted GM head 1mm Oversize QED stainless steel valves Double valve springs Titanium Retainers Solid lifters Cat camshafts Kent cams adjustable cam gears IgnitionMSD 4 tower coil Pack MSD Leads Iridium Spark Plugs DrivetrainF20 short ratio with LSD TS driveshafts Custom Billet steel flywheel Quartermaster Tripple plate clutch machined into a twinplate Arp pressure plate bolts InductionCustom inlet manifold 45mm Throttle bodies 775cc Fuel injector clinic injectors Custom fuel rail Custom ram tubes ManagementMSX        Updates to follow as i get further
sterlingesterhuizen
Posted: 06 Sep 2012, 05:31 |
| Cams, ITB's, Headjob, Management |
Joined: 09 Jul 2008, 11:59 Posts: 2991 Location: Kimberley
Nice gona be a killer!
But what's the reason for using 8 valve block?
_________________ Hers:Opel Corsa Chill 1.3 His: Are you kidding me???? When married it states "What is yours is mine what is MINE is MINE!!!! Ours: Chevrolet Cruze 1.6L
LeratoGP
Posted: 06 Sep 2012, 07:41 |
Joined: 07 May 2012, 12:15 Posts: 341 Location: Pretoria
Iyoo! Thars Wicked. 8v nice one. I would love to see it come alive.
_________________ Corsa C Ute Z18XE
"Love Never Fails"
TAUzty
Posted: 06 Sep 2012, 08:05 |
Joined: 19 Jun 2007, 10:49 Posts: 16181 Location: Detailing a ride
As always Pantera pulls all the stops , smart buddy cant wait till its done man finally a car to rip the vvl and b30's  a new one . keep us posted @pantera your f20 you using in this setup is it the same ratio as the one f20 you built for my car or will it be shorter ?
_________________ Race car : 200is Turbo 200.3kw and 405nm KILLER  . Family Car : E39 BMW 540i Individual 4.4 V8 Avus Blue 217kw and 460nm Stock Standard .
8 Valves of glory
Posted: 06 Sep 2012, 08:36 |
Joined: 18 Jul 2008, 12:15 Posts: 3914 Location: Lost
sterlingesterhuizen wrote: Nice gona be a killer!
But what's the reason for using 8 valve block? same blocks
_________________ Current: 98 Ballade 180i EX: Monza CD16V Ex: GSI Boss 8 valve
sterlingesterhuizen
Posted: 06 Sep 2012, 09:00 |
Isn't there a bit of difference to make 16valve head work on it?
8 Valves of glory
Posted: 06 Sep 2012, 10:13 |
yes there are a few changes that need to be made. will send you plenty of pics in about a month or two
sterlingesterhuizen
Posted: 06 Sep 2012, 10:19 |
Coolio I'll be waiting the pics
Kalu
Posted: 06 Sep 2012, 10:53 |
sterlingesterhuizen wrote: Isn't there a bit of difference to make 16valve head work on it? The 16v block and 8v block are the same. Its only if you take a standard 16v or 8v sub assembly and try fit the other head then you must change things.
_________________ 2005 Honda Accord Type S - K24A3 - 122WKW 200Nm @ JDM Worx 1997 Corsa B X20XEV EX - 2003 Ph3.5 Astra Coupe - 210KW 437Nm - 17/02/2011 @ KSD
Pantera
Posted: 06 Sep 2012, 11:11 |
The only difference between the blocks is the 16v has an oil restrictor built into the block with a non return valve, Im using solid lifters so i need less oil going to the head, so i have machined a bolt that screws into the block to restrict the oil flow
crispy boss
Posted: 06 Sep 2012, 11:17 |
yoh yoh yoh.
this is mos gonna be a natkat
_________________ Current: '13 Alfa Romeo MiTO Quadrifoglio Verde Sport 125kw 250nm Dont take life so seriously
Ex: '12 Fiat Bravo Sport 110kw 235nm '11 Kia Koup 122kw 203nm '08 Daihatsu Sirion Sport 1.5 VVTi '02 Euro Opel Corsa 160is '85 Opel GSI 2 door Boss
DevinC
Posted: 06 Sep 2012, 11:25 |
| Filter, Exhaust & Branch |
Joined: 30 Oct 2011, 19:08 Posts: 663 Location: Edgemead, CPT
Going to be one n/a monster of note..
_________________ Current: '03 Golf Mk4 GTi Ex: '97 Golf Mk3 GTS 1.8i - SlowBlob Ex: '93 Opel Kadett 1.4 + 36DCD - Popcorn Machine
adrian.trout
Posted: 07 Sep 2012, 12:09 |
| Filter & Exhaust |
Joined: 23 Nov 2011, 11:28 Posts: 490 Location: Northern Suburbs
Brilliant stuff Luc!
Posted: 07 Sep 2012, 12:16 |
Ecotec16v
Posted: 12 Sep 2012, 08:52 |
I can't wait for this to finish! Luc when you run the crap out of the Hondas and Nissans they gonna say they're running low comp setups
_________________ 1999 Opel Kadett 200iSE 60kw 18.5s
yusufallie
Posted: 12 Sep 2012, 09:40 |
Joined: 30 Sep 2010, 13:53 Posts: 1098 Location: sitting in my seat waiting for the boost .....
Ecotec16v wrote: I can't wait for this to finish! Luc when you run the crap out of the Hondas and Nissans they gonna say they're running low comp setups  nooOO THEY GONNA SAY THEY RUNNING STOCK SETUP.
_________________ ASTRA GTC OPC-line
WezGSI
Posted: 12 Sep 2012, 09:41 |
Joined: 15 Mar 2007, 12:46 Posts: 5458 Location: kuilsriver
All the best for the build! Another n/a monster.
_________________ Opel Club Cape Town Chairman My Ridez Opel Kadett Superboss  16vS 20 XEToyota Prado 3.4 V6 VXHyundai Getz R Open-filter-box 16 vEx Ridez 2000 Opel Corsa B  1.8 16v  conversion 1991 Opel Cub 1.6i 8v c16ne conversion
Diablo69
Posted: 12 Sep 2012, 17:31 |
Joined: 24 Jun 2010, 13:32 Posts: 1834 Location: in the workshop..
best of luck with this build Luc!No doubt its going to be another MONSTER!!!
_________________  Opel Corsa B 2.0 16V ITB 166.1kw 226nm ( Project Thread --> - Project Diablo ) Honda Fireblade 1000 133KW Subaru 2.5WRX STI Hatch 257kw 495nm
Pantera
Posted: 23 Sep 2012, 04:01 |
crispy boss
Posted: 23 Sep 2012, 09:55 |
Damn
