Post new topic Reply to topic  [ 3 posts ]
 Post subject: 200is Euro kadett
 Post Posted: 28 Feb 2014, 10:22
hi guys i drive a 2L8v Euro and the only mod i did so far was cone filter lol, the car runs beautiful but the bug has bitten me so now i need to know if the mod i hav in mind is worth it on more power gains not lookin to turbo
wana know how this sounds, 278 billet cam, port & gasflow head, swirled valves, branches, 57mm exhaust, knife edged crank, lightened flywheel and a unichip
Current: Kadett 200iS
Ex: 160iS Astra, branch n freeflow
Ex: Boss Gsi
Ex: 200i Astra Euro, 272
Ex: Kadett 200iSE, STOLEN
Ex: Corsa B Gsi
Get your SHIFT together
 Post subject: Re: 200is Euro kadett
 Post Posted: 28 Feb 2014, 11:26
if you serious about this do i right once pal.
1st start off by getting a full management system which will give you total control of the car .
And you can rid of all the stock rubbish like ICV,airflow meter ect!
Do the cam,do the porting of the head and the valves, fit 4-2-1 branch , fit 63mm exhaust . Rather get the complete engine balanced go to dice perfromace mr Dave Ingle he can do it and did mine and probably 100s of other mk1 golfs.
leave the crank as it is.
deck the block ,fit xe pistons,skim the head .
in injection form the 8v should be pushing close to the 115kw mark!
if throttles added you will be pushing from 125 to 140kw and way over 205nm of torque.
There is also enough info on this forum about different 8v builds best to search abit that was just a 5c from my side!
 Post Posted: 28 Feb 2014, 14:02
thanx bud will rather go for the throttle setup den.... Wir leben Autos!
Ex: Boss Gsi
Ex: Corsa B Gsi
