Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: TS ecotec rebuild
 Post Posted: 26 Sep 2008, 11:13
Good luck buddy...should be good fun.
Sounds like another hectic project...estimated time to completion??
"To win without risk is to triumph without glory"
1998 Kadette 200is
2.5 V6 Conversion
2007 Zafira
 Post Posted: 26 Sep 2008, 11:18
4weeks. have sort out my gearbox as well
MSX Forum
Corsa 130ie Sedan
1680 16v Ecotec
GSXR1000 ITB's (44mm)
MSX Management
149.8kw/203Nm
 Post Posted: 26 Sep 2008, 11:19
don't worry bru. your engine is on the stand.
MSX Forum
Corsa 130ie Sedan
1680 16v Ecotec
MSX Management
149.8kw/203Nm
 Post Posted: 26 Sep 2008, 11:37
Im not the type to worry about such things bru... patience is my strongest virtue....but i see ur reading between the lines :-)
1998 Kadette 200is
2.5 V6 Conversion
2007 Zafira
 Post Posted: 26 Sep 2008, 13:44
GUD LUC. I STRIPPED MY ENGINE WED AND IM CONSIDERING NOT PUT TURBO GOODS BACK.
 Post Posted: 26 Sep 2008, 13:52
what happend to your engine?
MSX Forum
Corsa 130ie Sedan
1680 16v Ecotec
MSX Management
149.8kw/203Nm
 Post Posted: 26 Sep 2008, 14:19
broke number 4 piston. damage to the bore and combustion chamber aswell. dnt actually wna spend all that money on wiseco or arias pistons. one part says buy pistons and rebuild engine other part says build a........................................
TOYOTA!!!
 Post Posted: 26 Sep 2008, 14:21
^buy the pistons
 Post Posted: 26 Sep 2008, 14:28
Buy the pistons
MSX Forum
Corsa 130ie Sedan
1680 16v Ecotec
MSX Management
149.8kw/203Nm
 Post Posted: 26 Sep 2008, 14:43
its becoming to unreliable and the body tore aswell.so i dnt kno.i might rebuild but then im gna sell the car. do you think its easier to sell a n/a than a turbo car?
 Post Posted: 26 Sep 2008, 14:57
keep it bru...
 Post Posted: 26 Sep 2008, 15:03
na. enuf bout me this is the profs thread.
 Post Posted: 26 Sep 2008, 15:04
It sounds like its gonna be a stunning build... Wink
'You want some...come and get some...'
^then start your own thread...the silvercd thread
 Post Posted: 26 Sep 2008, 22:37
will be watching this thread. good luck with the build. i know this will be the yardstick opel Cool
 Post Posted: 29 Sep 2008, 09:11
Will keep it a family sedan for the next year ,with alittle spice, the decide it's future at the end of next year. Might sell or strip the weight and made it a permanent drag car. If it’s the later, it will become rear wheel drive.
MSX Forum
Corsa 130ie Sedan
1680 16v Ecotec
MSX Management
149.8kw/203Nm
 Post Posted: 29 Sep 2008, 09:24
:shock:
 Post Posted: 29 Sep 2008, 11:31
ts drift machine,
of moet ek se, drift astra
 Post Posted: 29 Sep 2008, 11:32
So engine and gearbox out on Saturday. Engine tripped and ready for the engineers.
List of duties for the engineers
Re-sleeve block - new pistons are 20thou but block currently on 60
Machine the main caps flush with the rest of the block to make provision for the girdle
knife edge the crank. This has 2 benifates
1. makes the crank more streamlined so that there less aerodynamic forces playing up against it at high revs. Beneficial when you wanna rev to 9k+
2. makes the crank a bit lighter but not too concerned about that. lighter bottom means less torgue.
MSX Forum
Corsa 130ie Sedan
1680 16v Ecotec
MSX Management
149.8kw/203Nm
 Post Posted: 29 Sep 2008, 16:37
For those of you that would like to know what the girdle looks like.
MSX Forum
Corsa 130ie Sedan
1680 16v Ecotec
MSX Management
149.8kw/203Nm
