Post new topic Reply to topic  [ 108 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: ATT: Tauzty
 Post Posted: 18 May 2010, 14:51
Tanx CA! :duim:
Ex: 2009 Astra OPC+
Ex: 2007 Astra H 1.9 CDTI
Ex: 2007 Astra H 1.8 sport
Ex: 2003 Astra G 1.8 16v
 Post Posted: 18 May 2010, 20:48
278's forsale on teh ooc forum!
 Post Posted: 18 May 2010, 21:51
Yor Tanx crispy! just PM'd the guy now. Have to make sure that they will fit the z18xe first, cause the z18xe cams are different to the x18xe1 cams I heared.
Ex: 2009 Astra OPC+
 Post Posted: 19 May 2010, 12:52
How much power are you aiming for with this setup?
"Loved by few, Hated by many, but Respected by All" - Ecotec
 Post Posted: 19 May 2010, 13:19
Im aiming for about +-125kw with this setup, think its reasonable topper?
Ex: 2009 Astra OPC+
 Post Posted: 20 May 2010, 10:19
When fitting ITB's to the ecotec engines, you will need to seriously up the rev-limiter. You will only start making power higher up in the rev range since the ITB's needs greater air speed to operate optimally(I think I said that correct). Hence you will need to rev till about 8k - 8.5k.
But then the next question will be : How will my bottom-end handle this?
That is when you start looking at steel rods, for example, to help prevent things from braking at the bottom.
 Post Posted: 20 May 2010, 10:24
I'm pretty sure you will make much more power Ecotecs make lekker power
 Post Posted: 20 May 2010, 11:04
OPEL GURU
OPEL GURU
You just need to run longer ram tubes to bring the powerband down, but with 45's it will never make power to 8500rpm without wild cams.
 Post Posted: 20 May 2010, 11:27
Ohk here's an update....
I got 43's in the week, with a brand new set of dave ingle 80mm ram tubes. Thinking of getting those 278's that are for sale on the OOC forum. My limiter is currently factory set on 6.5k, wanted to move it to 7k, maybe 7.5k max, but it depends on the power band ofcourse.
So with 43's, 80mm tubes and 278 cams, anyone have an estimate on the power band rev range?
Ex: 2009 Astra OPC+
 Post subject: Re: Z18xe ITB
 Post Posted: 26 May 2011, 11:16
Instead of starting a new thread, ill just continue with this one (changed subject).
Update.....Manifold is basicly done, just needs a few adjustments and its good to go.
Bottom end.....saving for steel rods and ARP's, will be using a set for the 1600 corsa, 129.75mm iirc, same size as the 1800.
Fueling....will be getting aftermarket pump, AFPR and thinking of changing injectors, I read current ones are 210cc??
And then thats all the parts.
ET for completion....sometime around July/August
Ex: 2009 Astra OPC+
 Post Posted: 26 May 2011, 12:45
looking forward to the end result. . good luck
 Post Posted: 26 May 2011, 12:51
Thanks! :duim:
Im interested to see what it can reach.
Ex: 2009 Astra OPC+
 Post Posted: 26 May 2011, 12:55
you already so fast, now you going be even faster, these thundercats of today, lmbi, only jokes
you still driving at the back, lol
good luck with the build
soon 200SX S13
 Post Posted: 26 May 2011, 13:01
Thanks buddy!
Haha!! Ok I'll drive at the back :bites:
Still some way to go, but im gonna get it done.
Ex: 2009 Astra OPC+
 Post Posted: 26 May 2011, 18:02
yay!!! :whoop: Looking forward to this one being finished.Then me ang you can drive next to eachother and make noise at every convoy :mzekezeke:
Opel Corsa B 2.0 16V ITB 166.1kw 226nm ( Project Thread --> - Project Diablo )
Honda Fireblade 1000 133KW
Subaru 2.5WRX STI Hatch 257kw 495nm
 Post Posted: 27 May 2011, 09:39
Lol thanks dude, we will be deaf after a few convoys :lol:
Ex: 2009 Astra OPC+
 Post Posted: 27 May 2011, 13:31
hahahaa :mrgreen:
 Post Posted: 30 May 2011, 21:54
Time for :smile:
Picked-up Manifold today, not the best work I've seen but still pretty good imo.
Ex: 2009 Astra OPC+
 Post Posted: 31 May 2011, 00:50
Nice
What was the price ?
U812
 Post Posted: 31 May 2011, 09:21
Lekker
Users browsing this forum: No registered users and 22 guests
