Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3  Next
 Post subject: Newbie
 Post Posted: 21 Jul 2010, 13:51
Ok Howzit okes
I'm new to the forum thing - but looked like a cool place to learn some new things.
I have a 03' Opel Corsa 1.4i. After a year of driving with 155 13inch wheels and bugger all power i got bored.
So this last week i put 15inch from Goodhope Tyres, full exhaust system from powerflow (branch included) and a Simota induction kit. Also having car colour coded as i type this, fitting fog lights and fitting wing.
I have bought a SMT6 piggy back chip that will put on after i put in a 270 duration cam, which i am waiting for from Master Cams( no one else seems to stock).
What i need help with is following: I have a crappy blue instrumentation cluster with no rev counter. I sourced one from a 05' model, its like a grey with a rev counter. Problem is it is electronic and as far as i can tell my existing one isnt. Anyone had any experience with this, i really want to fit it in.
Also anyone have any idea what kind of power i'll be looking at after chip goes in. Zeeline Performance will dyno it for me.
03 Opel Corsa 1.4i
Brospeed Branch
Powerflow Exhaust
01 Corsa 1.4i UTE
96 Honda Ballade 1.6i 16v
95 Opel Astra 1.6i
 Post subject: Re: Newbie
 Post Posted: 21 Jul 2010, 13:57
hey howsit
Why not a 272 cam ? I cant help you with the clocks, I would have just put in an aftermarket rev counter.
good luck
U812
 Post Posted: 21 Jul 2010, 14:00
Welcome man & enjoy :wave:
pop around to one of our monthly hookups..would like to check your cab out :duim:
 Post Posted: 21 Jul 2010, 14:11
Shot for comments :thumbup:
ok so i have now sourced a 272 cam from Goldwagen Bellville and can collect it on way home. Same price but more pull off - shot Mischif, its better than Master Cam cutting a standard 1.4i cam for me.
I was thinking about after market Rev counter, but i really hate the blue!!! Also i want it to look stock and neat...
Ja i'm keen to meet up with some of you guys, get some more ideas. Like maybe a 1.8 transplant???.....
03 Opel Corsa 1.4i
Brospeed Branch
Powerflow Exhaust
01 Corsa 1.4i UTE
95 Opel Astra 1.6i
 Post Posted: 21 Jul 2010, 15:16
Ok so i am starting to worry about the cam. Is a 272 right for the 1.4? Also how difficult is it to install? I wont be doing it myself but a friend of mine is. does it need to be tuned?
Any help would be cool. Normally i just give the car to a mechanic but i would like to get my hands dirty and learn something new.
03 Opel Corsa 1.4i
Brospeed Branch
Powerflow Exhaust
01 Corsa 1.4i UTE
95 Opel Astra 1.6i
 Post Posted: 21 Jul 2010, 15:40
30min max to install :) .
272 is fine and it will work great on a 1.4 nothing wrong with it .
 Post Posted: 21 Jul 2010, 15:44
agreed with tauzty.
welcome and enjoy.
as for the clocks, the new one might not work at all.
2003 Opel Astra GSi
1982 Volkswagen Golf MK1 GT - under construction
2000 Opel Corsa GSi (C20XE - 15.5s @ Tarlton)
2006 Chevrolet Aveo 1.5 LS (R.I.P written off :( )
1995 Opel Kadett 200t S(stock standard except lowering springs) - R.I.P
1997 Opel Corsa 130i E(viper branch & f/f,70/40 drop,derestricted airbox!) - sold
1989 Opel Kadett 160 GSE(stock standard) - sold
 Post Posted: 21 Jul 2010, 15:50
welcome bru
1988 opel kadett 1600 gl
70.6KW
141 NM
 Post Posted: 21 Jul 2010, 15:55
agreed with tauzty.
welcome and enjoy.
Well that will suck. I called Mikes Auto Electrical out in retreat, he said they might be able to work something out. Hope so. Otherwise anyone wanna buy a Instrumentation cluster? :)
03 Opel Corsa 1.4i
Brospeed Branch
Powerflow Exhaust
01 Corsa 1.4i UTE
95 Opel Astra 1.6i
 Post Posted: 21 Jul 2010, 16:30
+1 for the 272 its gna have a nice lumpy idle.
The electronic clocks you have start @ 0km/ph they can work.
Iirc you have to change loom and gbox sensor.
To much effort 4what its worth.
Just get a cluster thats starts at 20km/ph,those are cable driven.
Ie/is/gsi20km will be plug nd play,you mite have to connect the rpm wire but thats easy.
Goodluck guy
Vdub VR6 :correct:
Nissan 200sti :correct:
Honda vtec (civic)
Toyota RSI
Toyota runx rsi
Toyota bubble gli :correct:
Ford fiesta st :correct:
 Post Posted: 21 Jul 2010, 16:39
RPM WIRE green wire by the coil :) most opels so yaa run that through and rev counter should pop up :duim: ...
get a pre 97model corsa cluster man got alles inn.
 Post Posted: 21 Jul 2010, 17:33
Huh? Pre 97?
On the corsa if you take it frm the coil u get a low volt reading.
Needs to go to the ecu pin 42 i thnk, will get back on that but yea green wire.
Vdub VR6 :correct:
Honda vtec (civic)
Toyota RSI
Toyota runx rsi
 Post Posted: 22 Jul 2010, 09:00
RaCing1 wrote:
Huh? Pre 97?
Oh i know when you connect a aftermarket rev counter and to get accurate it comes from that green wire, but thanks buddy didnt know about pin 42,
see informative thread! :duim:
 Post Posted: 22 Jul 2010, 10:23
OPEL GURU
OPEL GURU
The green wire sits in a 6pin plug next to the computer box, the wire going to the clocks isn't there, you you just connect the green wire from the 6pin connector to the back of the clocks, and it will work.
130i or 130is or 1.6gsi etc clocks will fit in there, then you just add the rpm wire and you done.
 Post Posted: 22 Jul 2010, 10:30
similar on our F-series hey . . that's how I made my rev counter work now since the managment is fitted
 Post Posted: 22 Jul 2010, 10:59
Shot for all the help.
I recon i need the Corsa sport or GSI clocks from like a 97 model. Gonna sell the 05 clocks i bought or try swap em.
Bumpers are painted now, just need to fit them back on the car, also got my 272 cam from Master Cams. They said that it will run smooth, not to lumpy. I think tomorrow i will try fit the SMT6 Chip to car and then take it for a dyno on saturday.
I'll post some pics of cam going in later today. Here are some (low quality phone pics) of sprayed bumpers.
03 Opel Corsa 1.4i
Brospeed Branch
Powerflow Exhaust
01 Corsa 1.4i UTE
95 Opel Astra 1.6i
 Post Posted: 22 Jul 2010, 11:03
Below pics - sorry for poor quality. The bumpers need to be polished next. Will try that tonight.
File comment: Clocks i wanted to use
File comment: Primed bumpers
File comment: Colour coded bumpers
03 Opel Corsa 1.4i
Brospeed Branch
Powerflow Exhaust
01 Corsa 1.4i UTE
95 Opel Astra 1.6i
 Post Posted: 22 Jul 2010, 11:07
looking good buddy :duim:
 Post Posted: 22 Jul 2010, 11:12
Hey Crispy - i want to try get light like you have on your Corsa. I friend told me a way of blacking out the existing lights. It sounds a little crazy tho (something about putting them in the oven!!!) but i he did it to his 98 1.5i Civic and it looks flipping good. Otherwise i was thinking about crystals? What do you guys think?
03 Opel Corsa 1.4i
Brospeed Branch
Powerflow Exhaust
01 Corsa 1.4i UTE
95 Opel Astra 1.6i
 Post Posted: 22 Jul 2010, 11:22
call this guy
REZA
0833080636
they have a shop in n1 city i think,...
take your lights to them
Users browsing this forum: No registered users and 120 guests
