Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: Project TS
 Post Posted: 10 Sep 2010, 10:26
OPEL GURU
OPEL GURU
Getting my TS back up and running to the spec i want it to be. The car was driving until i removed the larger turbo setup and sold it. I will now be re-doing everything to the spec i want it. Building a new Manifold, downpipe etc. Same turbo as the corsa is running.
Things i have already that are going in:
1000cc RC Injectors
Ball bearing turbo
Electronic boost controller
Quaife diff
Water cooled oil cooler
GTC Calipers with 308mm disks
Things on the way:
Tial 44mm wastegate
Trunk mount water/meth kit
Things that need to be made:
Manifold
Downpipe
Boost pipes
Aircon lines
Power steering lines
Custom Radiator
Radiator fans mount
Coil overs for the front struts
The car will have a bigger turbo, working A/C, remaking the power steering lines, so that they run where i want them to, same with the A/C lines. Custom radiator will fill up the space where the stock cooler went, wiring will be run for the Fans so that the MSX turns them on instead of the two fan switches on the stock radiator.
The engine already had the right groceries in it. ie wiseco pistons, scat rods, arp head studs, etc etc. but will be stripped and new rings and bearings and gaskets will be fitted.
 Post subject: Re: Project TS
 Post Posted: 10 Sep 2010, 10:30
:respek:
Nice...Good luck :duim:
So you gonna be bringing it to Killarney, when it's done?
 Post Posted: 10 Sep 2010, 10:39
:whoop:
This will be a good build to follow.
She gona be set-up for the track? or just to prowl the streets?
Ex: 2009 Astra OPC+
Ex: 2007 Astra H 1.9 CDTI
Ex: 2007 Astra H 1.8 sport
Ex: 2003 Astra G 1.8 16v
 Post Posted: 10 Sep 2010, 10:47
Nice
Sounds like fun :duim:
U812
 Post Posted: 10 Sep 2010, 10:54
OPEL GURU
OPEL GURU
Will only go to Street to strip events, although i might have to run lower boost cause i think it will do 12's on street tyres. Won't bring it to an MSA event with slicks etc as there is no point, the corsa would be far faster.
Will be primarily for street use. Got a nice sound system in the car, and with a working a/c and alot of power should be a nice ride.
 Post Posted: 10 Sep 2010, 10:56
nice :duim: :respek:
can't wait to see when it is done
 Post Posted: 10 Sep 2010, 11:10
Understatement man! Will be an awesome ride, all the power with all the comfort features and some db's ringing in your ear lol
Ex: 2009 Astra OPC+
 Post Posted: 10 Sep 2010, 12:48
cool man. that looks like a nice shopping list you got there!
Would be great the see it once its done. What is your timeline on this project?
My Ride:
94 Kadett 200tS Under construction
07 Corsa UTE
 Post Posted: 10 Sep 2010, 12:56
OPEL GURU
OPEL GURU
Wanna have it done in the next 3 months. Need to fabricate the manifold first, then remove engine and gearbox, respray the engine bay fit the quaife and do a quick rebuild.
 Post Posted: 10 Sep 2010, 13:19
All the best with the build Luc. Now stay off 'that' forum :mrgreen: Jy maak mense groen!
 Post Posted: 10 Sep 2010, 13:42
this looks nice, gonna be unfair for you to have such a nice car and i don't :ohno:
 Post Posted: 10 Sep 2010, 14:18
Nice project Luc!!Gona be another ripper.U going to be working December? or u going away on holiday etc.?
Opel Corsa B 2.0 16V ITB 166.1kw 226nm ( Project Thread --> - Project Diablo )
Honda Fireblade 1000 133KW
Subaru 2.5WRX STI Hatch 257kw 495nm
 Post Posted: 10 Sep 2010, 14:36
OPEL GURU
OPEL GURU
No, i won't be going away, hard for the wife to get off work, she has to book her leave like a year in advance. I normall get quite alot done in december.
 Post Posted: 10 Sep 2010, 15:04
Anothere MONSTER in the making!!!!!!!!!!! :duim: :respek:
SuperBoss Auto Spares
Pretoria
Cell:0849860444
 Post Posted: 10 Sep 2010, 15:56
ok decent :mrgreen: Will see u in Dec with my project? :duim:
 Post Posted: 10 Sep 2010, 16:21
Major :respek:
Which coilovers? Is the opel secret combination koni shocks with eibach springs? Goodness of luck :duim:
 Post Posted: 11 Sep 2010, 10:30
would you consider selling it? if so, what price
just curious what a well sorted TS would go for
Please MTV.. Pimp My Ride
 Post Posted: 11 Sep 2010, 10:36
nice uncle Luc!
dont forget the carwash and polish nuh :lol:
 Post Posted: 11 Sep 2010, 11:46
OPEL GURU
OPEL GURU
Nah dude, i would never sell it, if i had to i would have to ask 150k for it just to break even. It will be the cleanest TS anyone has seen believe me.
 Post Posted: 11 Sep 2010, 20:46
Good luck bru....at least this will keep the cobwebs and dirt of that beauty.
Please give that advice to that friend of ours, whose Astra is busy fossilising in his garage :mrgreen:
All the best man...hope the build goes well :duim:
"To win without risk is to triumph without glory"
1998 Kadette 200is
2.5 V6 Conversion
2007 Zafira
Users browsing this forum: No registered users and 178 guests
