Post new topic Reply to topic  [ 7 posts ]
 Post subject: Amp Suggestions please
 Post Posted: 06 Sep 2012, 13:59
What would be a good amp for this sub?
its an INFINITY REFERENCE 1240 12inch SVC:
Power Handling, RMS 300 W
Power Handling, Peak 1200 W
Frequency Response 33Hz-300Hz
Nominal Impedance 4 ohms
Sensitivity (2.83V@1m) 91 dB
Enclosure Type 3/4" (19mm) MDF bass-reflex, with Slipstream port
95 200is 8v
 Post Posted: 07 Sep 2012, 23:38
ice power pro series amp 3000w
 Post Posted: 08 Sep 2012, 10:54
The 4 channel 3200w pro series? i cant find the rms ratings and what not for the amp but you reckon it would work leka?
95 200is 8v
 Post Posted: 10 Sep 2012, 07:11
what else do you plan on running in the car? have you got any other speakers or amps in at the moment?
whats your budget like? are you willing to spend for the quality of sound or are you on a tight budget still wanting good quality?
these are the RMS ratings for the ice power amp:
Product Code: AMP-ICE-PS3200
150W X 4CH @ 2 Ohm RMS
100W X 4CH @ 4 Ohm RMS
 Post Posted: 10 Sep 2012, 08:12
No plans of running anything else at the moment guy, deck is powering my 6x9's and mids fine, car's exhaust is just drowning out the base haha...if the quality of sound is gona be good and clean then I might be willing to pay, but otherwise I don't really wanna fork out too much you know? Just want something that will drive the sub nicely and give good base
95 200is 8v
 Post Posted: 10 Sep 2012, 13:28
6x9's and mids on the deck is not nearly as good as it can be when running from an amp.
if you do go for the ice power mentioned above you can run a set of speakers as well as the sub from the amp and it will play a whole lot better. but get someone to wire it up properly for best results.
i would run a decent set of mids and the sub from the amp and then run the 6x9's from the deck.
 Post Posted: 10 Sep 2012, 17:15
Sounds like a plan...thanks my man
95 200is 8v
