lelanipelser
Posted: 13 Dec 2012, 16:04 |
Hi,
Does anyone know how to remove a factory fitted 2007 Corsa lite 14i sport radio? The thing does not want to play anymore. Checked all the fuses in fuse box , no problem there. Is there maybe another place where the problem might be?
Nathan_K UTE
Posted: 19 Dec 2012, 02:29 |
| Upgraded to a Flatbed Filter |
Joined: 07 Jul 2012, 08:32 Posts: 141 Location: Stellenbosch
is it completely dead? or does something look like it wants to come on?
_________________ Current: 2006 Corsa C UTE 1.4 club Ice: 4 x 10" targa street+ subs running of targa 2.8 KZ 6.5" DBX Polk audio splits and 5.25" DBX Polk audio co-axials Running of ice power 1200.4
Ex: 2002 Polo Playa 1.4
lelanipelser
Posted: 19 Dec 2012, 14:29 |
It is completely dead. My battery died, and some smart ass. Tried to fix "the relay starter cable" by bridging between fuses with a paperclip. Well he got a shock, and since then the radio does not work. Now I know it is not the fuses, took each one out, and none blown. There is a fuse behind the radio, but I can't get to the thing, as I can't get the radio out. That is my problem, getting it out......................... Bleh!
Nathan_K UTE
Posted: 19 Dec 2012, 22:57 |
There are generally 2 ways of installing a head unit. One uses clips and the other screws. I personally have never seen a car with a screwed in radio but this method exists
Spring-Mounted Clips Inside car stereos held in place with this method have 4 small clips that prevent the unit from sliding out of the dash. You will need to buy a pair of U-shaped DIN tools in order to remove the radio. At the top of the "U" are small poles that engage the clips. Once inserted properly, you should hear a "click," and the radio should simply slide out of the dash.
Ps the U shaped DIN TOOLS looks like a ice sucker stick just thinnner, longer and made of metal
