Post new topic Reply to topic  [ 103 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post Posted: 01 Mar 2013, 09:26
Eish, thats heavy dude! Cambelt snaps are not a good thing.
Opel Club Cape Town Chairman
My Ridez
Opel Kadett Superboss Image 16vS 20XE
Toyota Prado 3.4 V6 VX
Hyundai GetzR Open-filter-box 16v
Ex Ridez
2000 Opel Corsa B Image 1.8 16v Image conversion
1991 Opel Cub 1.6i 8v c16ne conversion
 Post Posted: 01 Mar 2013, 09:55
8v motor should be safe man.
goodluck!
 Post Posted: 01 Mar 2013, 11:14
Chez 200is wrote:
Ouch, Hopefully its just a replacement belt you need. Was it a new timing belt?
It was once apon a time :lol: it failed due to age, not kilometers.
I was going to replace it this month, I can't believe it didn't make it for another two weeks!I was waiting for the money to be paid into my account as I am using the car for business now, so it is getting a lot more use. 500 business km this week already.
With the money I am getting paid per kilometer I could finally give the car some TLC. If this turns out to be a head off problem I am going to end up paying out of my own pocket to use the car for business :thumbdown:
Due to studies before this I haven't been able to afford to spend any money on the car since the rebuild, just been getting in and driving.
 Post Posted: 01 Mar 2013, 12:13
Ok so you haven’t really driven your car daily, 7000km came over a number years. Hopefully it’s just the belt. 20ne is safe, 20seh 50/50 chance there is no damage. Damn, you scaring me now, I only did like +/-2000km last year in the Kadett and the cambelt/waterpump change was over 3 years ago.
Anyway, let us know the outcome.
 Post Posted: 01 Mar 2013, 12:46
I will find out tonight, going to go pick up a new tensioner and belt after work
 Post Posted: 02 Mar 2013, 14:22
Update
2 rockers broken, so not too bad I guess. Was expecting worse. #2 inlet valve dropped, but luckily I don't see any damage. CAS wire also damaged, and the plastic cam belt cover doesn't mean much any more.
 Post Posted: 04 Mar 2013, 10:03
Ahhh thought I would find an update here of what went wrong. Goodluck and hope she be running soon buddy!
 Post Posted: 04 Mar 2013, 10:20
I gave up with updates on the Opel owners forum when they were having all those server issues.
Hopefully by next weekend, going to drop the head off tomorrow. Going to replace all the valves and seats.
 Post Posted: 04 Mar 2013, 10:42
It sounds like quite a bit of damage actually. Sorry to hear buddy. Maybe the 284 cam also contributed to the damage.
 Post Posted: 04 Mar 2013, 11:04
definetely, the longer duration and higher lift definetely decreased the chances of coming off scot free.
 Post Posted: 05 Mar 2013, 14:10
Mmm havent had any server issues lately...and yes true, modified cam increases the likelyhood of klapping a valve or two...been there a couple times :woot:
 Post Posted: 11 Mar 2013, 08:15
She runs again! Due to a stupid mistake due to working in the dark I only get her started at 21:00, will update in more detail later on in the morning
 Post Posted: 11 Mar 2013, 11:10
Update
I assembled the car over the course of the weekend. I had to do it in stages due to prior plans. Motor Masters had my head ready on Friday morning.
What I learned, 8v owners should take note:
Our heads have a design flaw. The amount of material between the inlet and exhaust valve seats is very thin. This leads to it cracking between the seats (due to the constant heating and cooling), and therefore the seats cannot be replaced! Once the seats are worn beyond repair your need to replace the head as a repair isn’t usually successful. My head has cracks between the seats on all cylinders. This is a pity as it turns out my head was a virgin before its first skim last week.
If you are buying a second hand head it is very important to look if there are cracks or not. Bad cracks can actually lead right into a water port running above it, causing coolent loss.
There are two different tensioners for our 8v’s. One with the spacer and once without. Mine has always been running the wrong one till now. I luckily found this out while on the phone to Masterparts. However, once I reached the counter the salesman did not ask me which one I wanted and supplied me the incorrect part, I had to tell him about the other one.
How do I know if I need the spacer or not? Look at your tensioner while it is on the car, is the belt running off about 2mm on the outside (away from the oil pump)? Or look at the wear on the pulley, where was the belt running? Simply saying I have a SEH is not good enough, there are still two different versions. I am not sure If this contributed to my cam belt breaking or not…
While trying to assemble the last few things with a torch I swapped the fuel lines inlet and return by accident. This led to a trouble shooting stint as the car wouldn’t start . All I am going to say is that it took a long while to end up back at the fuel lines.
The car is feeling very strong, I know I shouldn’t have been red lining it 4km after It was assembled but it pulled very strong till 6400rpm. The car also sounds different, good differnt
In a way I am happy the belt broke. I wouldn’t have known that all 4 inlet valves were leaking otherwise
 Post Posted: 11 Mar 2013, 17:51
Glad the car is running and that you so happy with it boet.
 Post Posted: 12 Mar 2013, 09:15
Happy its sorted. And thanks for the write-up. Many lessons learned, and lots of valued information. It will come in handy for all many of us. Thanks Gourami.
 Post Posted: 07 Aug 2013, 10:22
Gouraami wrote:
Update
Hey buddy,
Nice update you got here.
I had to change my head gasket as well due to head damage causing water and oil to mix. All sorted now. Think I have the tensioner with the spacer, as after I tightened the tensioner I noticed that there is still some play on it. Its almost like a spring mecanism.
Tell me what is the difference between the 2 tensioners and how do I know which one is the right one for my motor?
 Post Posted: 07 Aug 2013, 12:26
It tensions against the spring. I had my cambelt cover off on Sunday and noticed my belt was below the correct tension notch (belt stretched?).
You need to tension it against the spring till the arrow points to the notch. It will then move again once the engine rotates. I normally start the car and let it run for a bit, don't just let it idle, give it a few revs, you will see it move. Normally the tension will need to be adjusted again at this point.
The only difference between the two tensioners is how far out the roller is from the oil pump, the spacer bringing it further out. Once installed and tensioned up, feel if the cambelt is rolling on the entire width of the roller. If it is not you will then be able to determine if you need the one with or without the spacer
 Post Posted: 12 Aug 2013, 14:39
Got it buddy. Thanks for clearing this up :winkithumbs:
 Post Posted: 12 Aug 2013, 22:06
Do you have the correct one on?
 Post Posted: 20 Aug 2014, 16:47
More bad news. Turns out my chassis is bent.
The passenger side strut tower is pushed in towards the engine around 15mm. When I have time during December I will take the fender and fender liner off and take a look at what happened to it before I bought it. I can't see much from inside the engine bay.
When I bought the car it had heavy camber on the passenger side, but not realizing it was the chassis at the time I had the strut bent which sorted out the alignment 100%.
Moral of the story - Don't take me with to view a car for you :facepalm:
Users browsing this forum: No registered users and 7 guests
