 Post subject: Need help Please XTC?
 Post Posted: 17 Nov 2013, 14:41
I have a Opel corsa 1.4 utility
I want to put a lekker sound in, no competitions or heavy sound
Currently running a pioneer front loader
6x9 400w pioneer
200w mids of the desk
Now I wane but a amp and sub in!
Talked to the guy at sound match and car and sound shop
4000w XTC 4 channel amp
3000w 12" sub
And run the 6x9s and sub off amp, but heard in some cars the sub pulling the 6x9s dead? So any advise will be appriciated
 Post Posted: 17 Nov 2013, 15:13
I would personally run only the sub from the amp, unless you have a monoblock to carry your sub.
 Post Posted: 17 Nov 2013, 15:22
what's your budget for amp and sub? I assume the sub is also XTC? And if the amp is decent you shouldnt have a problem running both 6x9's and sub off a 4 channel. Most people do.
 Post Posted: 18 Nov 2013, 14:11
Bridge your connection on the 4CH for your sub, put the LP on and bass boost on.
Connect your 6x9s as normal on HP with treble boost on and you should be 100z.
You said you dont want banging sound. so that should be suffice. otherwise you will have to adjust your budget and get two Amps.
 Post Posted: 18 Nov 2013, 18:12
+1. And from the sound I've installed in friends cars, its usually the 6x9's that are way louder on the 4 channel rather than the sub. Then later if the bass is not enough anymore can just add a mono...
