GASOSSIOUS
Posted: 24 Jan 2014, 08:07 |
Joined: 11 Nov 2013, 08:45 Posts: 21 Location: somerset west
Hey guys i actually purchased a cold air pipe last weekend and i now want to install it, i want to fit it in the section where the fog lights usually go - as i have a 1.4is there is no fog lights and it just has the covers in the fig lights place - i want to remove the driver side one to fit the pipe - how does one remove it ... do you have cut it out or is it a bracket that just needs to be clipped out from the inner section of the bumper??
HELP NEEDED LOL!!!!!!
Posted: 24 Jan 2014, 08:08 |
It has to be cut out afaik
GASOSSIOUS
Posted: 24 Jan 2014, 10:51 |
any easy way stanley knife or recommended to remove bumper?
Posted: 24 Jan 2014, 11:01 |
Rather remove bumper, then cut
GASOSSIOUS
Posted: 24 Jan 2014, 11:02 |
ok awsom i am going to try this weekend cant be that difficult to remove the bumper i hope
Toy
Posted: 24 Jan 2014, 11:13 |
Joined: 22 Aug 2007, 01:30 Posts: 7994 Location: Afghanistan
GASOSSIOUS wrote: Hey guys i actually purchased a cold air pipe last weekend and i now want to install it, i want to fit it in the section where the fog lights usually go - as i have a 1.4is there is no fog lights and it just has the covers in the fig lights place - i want to remove the driver side one to fit the pipe - how does one remove it ... do you have cut it out or is it a bracket that just needs to be clipped out from the inner section of the bumper??
HELP NEEDED LOL!!!!!! wouldn't recommend this tho, too low... water WILL get in there.
_________________ "...And I'm not frightened of dying, anytime will do, i don't mind... Why should i be afraid of dying, there's no reason for it you've gotta go sometime..." Pink Floyd - Great Gig In The Sky  ex: '98 130i Snoek Bakkie ex: '04 Fiat Stilo 1.6 16V ex: '04 Mini Cooper S Current: Renault Clio 4 - 0.9 Tce  97 Uno Turbo
Posted: 24 Jan 2014, 11:21 |
Your car dropped gasman?
if its a std corsa b, its very high
Toy
Posted: 24 Jan 2014, 11:25 |
Corsa Addict wrote: Your car dropped gasman?
if its a std corsa b, its very high True, true...
GASOSSIOUS
Posted: 24 Jan 2014, 11:33 |
The car is standard height has a set of 17's on aswell , looking to swop the 17,s tho have them on gumtree need it lower.
its actually not a complete pipe it is the flex pipe you get - the bending type one - just to help supply cooler air cuz since i pt the branch in the engine bay is alot warmer then before - also looking at heat wraping the branch in the future want the car to breath better you know
Posted: 24 Jan 2014, 11:37 |
Rather get that branch powerkoted
Better than that heatwrap stuff imo
Koperdraad
Posted: 24 Jan 2014, 20:44 |
Corsa Addict wrote: Rather get that branch powerkoted
Better than that heatwrap stuff imo +1
_________________  10 Ford Bantam XLT 1.6 i EX: 04 Opel Corsa B 1.4 i SOLD Very Sad EX: 95 Golf MK1 1.3 SOLD
Koperdraad
Posted: 24 Jan 2014, 20:45 |
Rather take your head light out to fit it!! before u remove the bumper!!!
| Attachments: |
Posted: 25 Jan 2014, 18:18 |
whats wrong with heatwrap? Some expensive builds have them.
GASOSSIOUS
Posted: 29 Jan 2014, 14:15 |
WOW MAN THAT COLD AIR SETUP IS AMAZING!!!!!!
what did that set you back?
Koperdraad
Posted: 31 Jan 2014, 21:07 |
R850
JasonClifton
Posted: 07 Feb 2014, 12:07 |
| Filter & Exhaust |
Joined: 07 Feb 2014, 11:22 Posts: 337 Location: Edgemead, Cape Town
You have to cut them out. I cut mine out, but then I realized it was a mistake, cause I now have a CAI setup and my filter sits at the bottom now and you can see it through the hole. Will probably have the covers plastic welded in again.
_________________  Daily: 2005 Corsa Lite Jason Clifton Photography
Posted: 07 Feb 2014, 16:58 |
JasonClifton wrote: You have to cut them out. I cut mine out, but then I realized it was a mistake, cause I now have a CAI setup and my filter sits at the bottom now and you can see it through the hole. Will probably have the covers plastic welded in again. Fit fogs if you cut them out. Might as well.
Koperdraad
Posted: 08 Feb 2014, 10:23 |
DJ7 wrote: JasonClifton wrote: You have to cut them out. I cut mine out, but then I realized it was a mistake, cause I now have a CAI setup and my filter sits at the bottom now and you can see it through the hole. Will probably have the covers plastic welded in again. Fit fogs if you cut them out. Might as well.
