RapidoWP
Posted: 14 Apr 2014, 08:24 |
Water Wetter has been widely used in the USA for many years to get cars to run cooler. Go to "red line water wetter" on Google for more info. Now available from ROB on 0825755916
| Topic moved to 'Advertise your services' |
Klonkie
Posted: 14 Apr 2014, 08:39 |
a better link would have helped ... but ok .. heeeeeeere's GOOGLE! http://www.google.co.za/search?q=red+line+water+wetter
_________________ 2007 Opel Corsa Utility 1.4 2022 Toyota Corolla HB 1.2T 2024 Toyota C-HR 1.2T
Exes: 2015 Ford Ecosport 1.5 2014 Ford Focus ST 2.0T 2014 Opel Corsa OPC Nürburgring 1.6T 2005 Opel Corsa OPC 1.6T 2008 Volkswagen Golf GTi 2.0T 2005 Ford Territory TX 4.0 2004 Citroën C2 VTR 1.4 2001 Ford Fiesta Zetec-S 1.6 1998 Kia Sportage 2.0 1995 Fiat Uno Beat 1.4
Posted: 14 Apr 2014, 12:42 |
Would love to be at a tech talk where they elaborate on how it works and so on. Besides just reading up on it.
Posted: 14 Apr 2014, 12:44 |
And a price would also help the sale.
RapidoWP
Posted: 14 Apr 2014, 12:47 |
CALIB(C20XE)
Posted: 14 Apr 2014, 13:13 |
Joined: 17 Apr 2011, 22:55 Posts: 2436 Location: ON THE STREETS OF CPT
DJ7 wrote: Would love to be at a tech talk where they elaborate on how it works and so on. Besides just reading up on it. X2 I've seen a few write ups which swings both in a favour and also not in favour of the product so I fully agree.
_________________  0kw 0Nm
RapidoWP
Posted: 14 Apr 2014, 13:19 |
Google redlinewaterwetter
Posted: 14 Apr 2014, 13:23 |
Lol
yusufallie
Posted: 14 Apr 2014, 13:24 |
Joined: 30 Sep 2010, 13:53 Posts: 1098 Location: sitting in my seat waiting for the boost .....
RapidoWP wrote: Google redlinewaterwetter customer : "Hi, please tell me about the product you selling , RedlinewaterWetter, im interested" Seller: "Google redlinewaterwetter"
_________________ ASTRA GTC OPC-line
cyberpuppy
Posted: 14 Apr 2014, 13:37 |
| Filter, Exhaust & Branch |
It improves the cooling characteristics of your cooling system if you're running pure water without antifreeze/coolant. They acknowledge that it doesn't do much to antifreeze+water solutions. They say it "makes water wetter", which is tech speak for lowering the surface tension of water. They say it helps eliminate gas bubbles formed by high heat. So basically it does what your anti-freeze/coolant does: raises the boiling point of your coolant so it doesn't bubble at around 95-100 degrees Celsius( depending on how high above sea-level you are), eliminates or decreases oxidation (Rust) and improves the overall ability of the mix to dissipate heat.
In really simple terms: it's antifreeze/coolant but it's R270 instead of R40.
EDIT: This being said, I'm not saying ROB is a shark. I'm saying it's not worth it at R270. Maybe if he could organise a deal with the Redline guys to get it at a more "competitive" price... Ons is arm mense.
_________________ 2007 Subaru Forester XT 197kW and 380Nm of home-cooked, GTI embarrassing tuning. With a little help from Powerflow ex: 2005 Coupe 168kW 350Nm From Evo Performance
yusufallie
Posted: 14 Apr 2014, 13:45 |
cyberpuppy wrote: It improves the cooling characteristics of your cooling system if you're running pure water without antifreeze/coolant. They acknowledge that it doesn't do much to antifreeze+water solutions. They say it "makes water wetter", which is tech speak for lowering the surface tension of water. They say it helps eliminate gas bubbles formed by high heat. So basically it does what your anti-freeze/coolant does: raises the boiling point of your coolant so it doesn't bubble at around 95-100 degrees Celsius( depending on how high above sea-level you are), eliminates or decreases oxidation (Rust) and improves the overall ability of the mix to dissipate heat.
EDIT: This being said, I'm not saying ROB is a shark. I'm saying it's not worth it at R270. Maybe if he could organise a deal with the Redline guys to get it at a more "competitive" price... Ons is arm mense. you pay R230 for the value added JARGON
Posted: 14 Apr 2014, 14:13 |
yusufallie wrote: cyberpuppy wrote: It improves the cooling characteristics of your cooling system if you're running pure water without antifreeze/coolant. They acknowledge that it doesn't do much to antifreeze+water solutions. They say it "makes water wetter", which is tech speak for lowering the surface tension of water. They say it helps eliminate gas bubbles formed by high heat. So basically it does what your anti-freeze/coolant does: raises the boiling point of your coolant so it doesn't bubble at around 95-100 degrees Celsius( depending on how high above sea-level you are), eliminates or decreases oxidation (Rust) and improves the overall ability of the mix to dissipate heat.
EDIT: This being said, I'm not saying ROB is a shark. I'm saying it's not worth it at R270. Maybe if he could organise a deal with the Redline guys to get it at a more "competitive" price... Ons is arm mense. you pay R230 for the value added JARGON You pay R230 for the google redline water wetter.
cyberpuppy
Posted: 14 Apr 2014, 14:14 |
yusufallie wrote: you pay R230 for the value added JARGON
Also because Marikana effed up the exchange rate and there's lots of nice import duties because Jacob's Benz doesn't run on promises.
Posted: 14 Apr 2014, 14:15 |
RapidoWP wrote: Google redlinewaterwetter Refer to my post about besides reading up on it. Just trying to help you here. By just telling people to google it, won't help much with selling the product. Just saying. SA customer service at its best once again.
CALIB(C20XE)
Posted: 14 Apr 2014, 14:17 |
RapidoWP wrote: Google redlinewaterwetter I did google it Actually I would buy it from you but with a response as google it, I doubt I would want to do business with someone that has this attitude.
Klonkie
Posted: 14 Apr 2014, 14:19 |
I googled it too .. but then google said it omitted the adult-themed search results ... I'm guessing it has its other "wetter" uses too
yusufallie
Posted: 14 Apr 2014, 14:23 |
Klonkie wrote: I googled it too .. but then google said it omitted the adult-themed search results ... I'm guessing it has its other "wetter" uses too
Posted: 14 Apr 2014, 14:30 |
I thought this user was a spambot
Almost did not activate the account
I should have googled first
RapidoWP
Posted: 14 Apr 2014, 14:33 |
My apologies DJ7. When I posted I was not successful in uploading the info as an attachment. New to this forum and still cant upload
Posted: 14 Apr 2014, 14:35 |
RapidoWP wrote: My apologies DJ7. When I posted I was not successful in uploading the info as an attachment. New to this forum and still cant upload No worries, maybe you and the exec team can chat and possibly arrange an evening where you can explain to the peeps how it works. Would be a good way to get publicity as well.
