Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post Posted: 11 Jul 2014, 11:06
I found a DIY for the Corsa C from the UK froum. Here we go:
Note: This doesn't serve any sort of performance difference, but it does make a little more noise, better than putting a cone filter in in my opinion. I wasn't comfortable with drilling massive holes in my airbox, so this had to do.
Tools required for this is 1 phillips screwdriver, 1 pair of pliers, a drill or dremel, and some patience.
I assume you'll know how to open up your airbox, if you don't, close the bonnet and don't attempt this.
Once you've opened up the air box. You have this under the panel filter.
This is how to de-restrict the air box at the bottom. For this you can use a dremel or drill to get the plastic rivets off and end up with this result.
Once done with the bottom part, you find that the top part has this cone thing which needs to come out. It looks like this:
This cone thing can be cut off using a dremel or with lots of brute-force and swearing, it pushes out. If you have bad blood pressure, cut it rather. :lol:
Put your airbox back together, not forgetting to put the filter back in like I did :facepalm: and test it out :highfive:
Daily Lady: 2008 Yamaha YZF R6 - Hannah
Project: 2005 Corsa C 1.4i Club - Charlotte
"Just a 1400 with a loud exhaust and a cone filter" :mrgreen:
Build/Banter thread : viewtopic.php?f=30&t=26607
Ex Daily Lady: 2014 KTM Duke 390 - Lady Katlin (RIP)
Ex Adrenaline Rush: 1997 Suzuki GSX-R 750 SRAD
Ex Daily: 1992 VW Fox 1600
 Post Posted: 11 Jul 2014, 16:35
I don't think the top will flow better without the trumpet...
 Post Posted: 11 Jul 2014, 16:40
I removed the top trumpet and not the bottom. Like I said, I don't know whether this actually improves any performance at all. But it makes a leka sound and it's free :lol:
 Post Posted: 11 Jul 2014, 16:48
And the GM engineer responsible for the airbox commits suicide. Long development down the drain.
More noise is not equal to more power in this case...
Sent from my GT-I9100 using Tapatalk
.\X/.killa
2001 E39 530d
1987 E30 325i (RB25DET)
 Post Posted: 11 Jul 2014, 16:54
All this is true yes. But for somebody who wants a cone filter sound without the cone filter....
And with regards to the noise... please tell that to the people who make vacuum cleaners. Those things are way to f*****g noisy :chairtohead:
 Post Posted: 11 Jul 2014, 17:00
Woah! Attitude buddy...
You do know "why" a vacuum cleaner sounds like that, do you?
.\X/.killa
2001 E39 530d
 Post Posted: 11 Jul 2014, 17:04
Annnnnd then we say - thanks guinea pig.
No attitide Tino. None at all. :thumbup:
I know why a vacuum sounds like that yes. But it's quite annoying when you're trying to work on complicated boiler drawings when the cleaner comes and vacuums your desk :facepalm:
 Post Posted: 11 Jul 2014, 17:05
Btw. Shuda done it bfore UR dyno with old motor to see th difference
It was done before the dyno :shifty:
 Post Posted: 11 Jul 2014, 17:08
So you don't actually have a problem with the designer of the vacuum cleaner, but rather with you cleaning lady then? Okay...
All good. Different strokes for different folks.
.\X/.killa
2001 E39 530d
 Post Posted: 11 Jul 2014, 17:24
In theory Sound doesn't exist inside a vacuum,as some of you scientists may know,if not google it, cool thing to try is put your phone on voice record inside a vacuum cleaner,put it on for awhile,then remove the phone and press play,dead silent,only the sound of u opening the vacuum again obviously. Mind=blown. Ok I'm done.
 Post Posted: 11 Jul 2014, 17:28
Mybra... Nou praat jy k@k... The sound you hear is that of the air rushing... No. It's fine. I give up.
.\X/.killa
2001 E39 530d
 Post Posted: 11 Jul 2014, 17:40
Sound doesn't exist inside a vacuum. But that's because there's no air movement because there's no air that can move. So yes you are right :thumbup: , but not when it comes to a vacuum cleaner. Am I right Tino?
 Post Posted: 11 Jul 2014, 17:43
Wtf Viper? You said you know how a vacuum cleaner works...
.\X/.killa
2001 E39 530d
 Post Posted: 11 Jul 2014, 17:47
Just try it!
 Post Posted: 11 Jul 2014, 17:50
:facepalm: I'll just stick to brooms
 Post Posted: 11 Jul 2014, 17:59
So clearly only cosmetic and no performance gain
Ok the.
Carry on.
 Post Posted: 11 Jul 2014, 18:02
Viper... Airbox 101. All that stuff you took out is there to smooth airflow.
The sound you hear is turbulence. Turbulent air is "messy" and doesn't flow fast. So that free "mod" can also be detrimental.
.\X/.killa
2001 E39 530d
 Post Posted: 11 Jul 2014, 18:09
Many senses being made here!
