Koperdraad
Posted: 13 Jul 2014, 20:29 |
_________________  10 Ford Bantam XLT 1.6 i EX: 04 Opel Corsa B 1.4 i SOLD Very Sad EX: 95 Golf MK1 1.3 SOLD
Eddie738
Posted: 13 Jul 2014, 20:43 |
cool...can i run all the speakers and sub off one amp or should i get 2?
Posted: 14 Jul 2014, 07:57 |
Eddie738 wrote: cool...can i run all the speakers and sub off one amp or should i get 2? You going to need 2 unless you get a 5 channel amp.
Vitesh
Posted: 14 Jul 2014, 09:27 |
Joined: 06 Oct 2011, 16:04 Posts: 669 Location: Cape Town
thats a nice setup... will sound great, make sure you get a proper spec'd box for the sub, cz that MONO gonna rock it! Certainly will handle two subs as well.
if you're gonna go for big sound, which it seems you are due to the MONO block power and with you wanting to add 2 subs, you will definitely need a second amp to power your splits to make them audible over the pounding bass... you've got enough space to work with in the doors, so get a bigger, split system set.
use 4AWG power and ground wires and make sure you get a proper box for your sub/s. make sure your ground cable is secured on to the car chassis (sand paper the paint off where you connect it) have your power cord layered in on the left side of the car and your RCA's on the right to prevent ignition / grounding whine.
that should get u off to a good start
_________________ ____________________________________
2010 Corsa D 1.6 119Kw Turbo Sport 2010 Corsa D 1.4 Sport 80kw
Posted: 14 Jul 2014, 09:31 |
Vitesh wrote: thats a nice setup... will sound great, make sure you get a proper spec'd box for the sub, cz that MONO gonna rock it! Certainly will handle two subs as well.
use 4AWG power and ground wires and make sure you get a proper box for your sub/s. make sure your ground cable is secured on to the car chassis (sand paper the paint off where you connect it) have your power cord layered in on the left side of the car and your RCA's on the right to prevent ignition / grounding whine. that should get u off to a good start Good quality RCA's will also prevent this.
Vitesh
Posted: 14 Jul 2014, 09:32 |
DJ7 wrote: Vitesh wrote: thats a nice setup... will sound great, make sure you get a proper spec'd box for the sub, cz that MONO gonna rock it! Certainly will handle two subs as well.
use 4AWG power and ground wires and make sure you get a proper box for your sub/s. make sure your ground cable is secured on to the car chassis (sand paper the paint off where you connect it) have your power cord layered in on the left side of the car and your RCA's on the right to prevent ignition / grounding whine. that should get u off to a good start Good quality RCA's will also prevent this. indeed yesss +1
Posted: 14 Jul 2014, 09:35 |
With sound you should not get cheap anything. Your sound will only sound as good as your cheapest parts.
Pantera
Posted: 14 Jul 2014, 10:24 |
I won't ever use a Chinese amp again, I have a star sound in my ts which I'm going to replace with two JL Audio slash v3's
Sent from my iPhone using Tapatalk
Rolf
Posted: 25 Jul 2014, 14:06 |
Eddie738 wrote: im intending to mount the mids on the backboard and the 5" speakers in the doors. another option is to leave the rear-fill out for now, and get a better front-stage... I'm checking out the Soundmatch website and the Pioneer A1305C 5.25" components look decent. be sure to check how much clearance there is for the speaker motor structure in the door panel as well, and get some sound deadening for inside the door outer skin DJ7 wrote: Ok, kewl. Get a nice 4 channel to have them run off that instead of the deck. +1 this will get the best out of the components  enjoy it!
_________________ '09 Opel Corsa Utility 1.4 Club
Vitesh
Posted: 25 Jul 2014, 14:50 |
Any progress with your sound setup?
8 Valves of glory
Posted: 26 Aug 2014, 10:17 |
| Cams, ITB's, Headjob, Management |
Joined: 18 Jul 2008, 12:15 Posts: 3914 Location: Lost
just a quick question guys, how much are you paying per set of splits when going pioneer/jvc/sony?
personally i am not a fan and i have seen lightning audio's entry level stuff go for the same price and they play better... much better.
_________________ Current: 98 Ballade 180i EX: Monza CD16V Ex: GSI Boss 8 valve
Vitesh
Posted: 26 Aug 2014, 12:22 |
i actually need a new set,,, any ideas of insane sales?
8 Valves of glory
Posted: 26 Aug 2014, 12:50 |
don't know of any specials, but auto wizz was selling LA splits for some good prices recently. saw them going for R649 but don't know if the prices changed as this was about a month ago
high-knee
Posted: 28 Aug 2014, 09:03 |
Joined: 09 Sep 2013, 20:09 Posts: 41 Location: In some car's boot fixing the mess some oke made to his sound system!!!
Vitesh wrote: i actually need a new set,,, any ideas of insane sales? check out Soundmatch's facebook page. They have a clearance sale. Infinity splits for R400. supposedly demo stock but I don't know. its Saturday only. Don't know how many sets they have.
_________________ 2003 Corsa Classic 1.6 Elegance Engine:Stock Sound: Headunit - Alpine CDE-9874E Front - Standard Mids with some tweeters Amp - MTX Audio Thunder 81000D monoblock Sub - Audison Voce AV 12
Vitesh
Posted: 28 Aug 2014, 10:52 |
high-knee wrote: Vitesh wrote: i actually need a new set,,, any ideas of insane sales? check out Soundmatch's facebook page. They have a clearance sale. Infinity splits for R400. supposedly demo stock but I don't know. its Saturday only. Don't know how many sets they have. thanks ill take a drive this wknd
