 Post subject: Astra H Park Lights
 Post Posted: 30 Sep 2012, 19:39
Hey guys,
Any idea on how to replace the Park Light globe on the Astra H.
The whole head light has to come out replace one tiny bulb!
I have loosened the 2 bolts on top, but there must be a clip or another
bolt somewhere, as the unit does not want to come out. Any ideas?
 Post subject: Re: Astra H Park Lights
 Post Posted: 07 Sep 2014, 13:38
Hi.
The quickest way is to work from the wheel well.
Turn the wheel to a full lock.
There is a cover in the fender liner that will give you access to the back of the headlight.
Remove the cover.
Then remove the rubber cover that seals the bright lights.
You will find the park lights next to the brights.
PS: it's much easier to jack up the car and remove the wheel.
Enjoy!
