Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Corsa C 1.8 16v
 Post Posted: 18 Nov 2014, 23:18
Okay guys, like a few others on the forum i was also looking for a little something more out of the Corsa and decided to go the z18xe route.
The first engine was purchased 2 months ago, then while performing the cambelt service i noticed there was excessive play on the crankshaft. So back it went, then after empty promises of new stock arriving i settled on the x18xe1.
Some new goodies and upgrades
Fitted new cambelt kit and waterpump
Then came the really fun part, out with the old
Then i decided to give the gearbox a nice clean, as well as drain oil and fit new sideshaft seals
New clutch kit and gearbox fitted to the new engine
In with the new
Once i was happy with the way the engine was sitting i began customizing the cam side engine mounting. I was lucky enough to get a mounting with the 1.8 engine which helped a lot. This is what i have come up with, and is merely a guideline as to what could be done.
Original Corsa mount on left and Astra G mount(top piece and bolt) on right with engine bracket
I cut the tubular shaft off of the Corsa mount and drilled the hole bigger for bolt to fit through
Then came a lot of test fitting and alterations, i had to shave quite a bit more off of the Astra mount where it meets the shaft. Once the width issue was sorted i had to raise the mount in order to keep the engine level. Did this by cutting steel plates for each side as the body isn't level where the mount sits, there is a slight step up. This is a temporary solution, looking to have a proper one piece spacer made up. This is how its sitting at the moment.
Next up was fitting the branch, then having it towed down to have it connected to the existing Powerflow exhaust system.
Once i had the car back home i started connecting all coolant hoses and fuel line. Then once everything was in place i started with the wiring.
Once the car started i secured all the wiring connections and placed sleeving on to finish the look. Also found a nice place to mount the coilpack, thanks viper for the idea.
The end result
Car has just been road tuned so long and is driving well, hoping to have it dyno'd soon to give you guys some figures. Just want to say thanks to Carl with regards to wiring and starting issues.
'03 Opel Corsa 1.6 Sport
 Post subject: Re: Corsa C 1.8 16v
 Post Posted: 19 Nov 2014, 07:49
another 2 day build :duim:
 Post Posted: 19 Nov 2014, 08:45
Very Nice well done enjoy :ecotec:
 Post Posted: 19 Nov 2014, 09:39
Very Nice. Will definitely looking at how you did your mounting for my conversion in the future.
 Post Posted: 19 Nov 2014, 09:40
Nice build :2thumbsup:
Opel Club Cape Town Chairman
My Ridez
Opel Kadett Superboss Image 16vS 20XE
Toyota Prado 3.4 V6 VX
Hyundai GetzR Open-filter-box 16v
Ex Ridez
2000 Opel Corsa B Image 1.8 16v Image conversion
1991 Opel Cub 1.6i 8v c16ne conversion
 Post Posted: 19 Nov 2014, 10:04
Opel Club Cape Town PR & MARKETING
NIce Build man!!!
:OpelLogo: :Ecotec:
ex: '04 Alfa Romeo 147 2.0 selespeed
ex: '87 Golf mk1 cabriolet
ex: '95 Opel Calibra 2.0 16V :Calibra:
'06 Opel Astra H 2.0 T :Astra :Ecotec:
 Post Posted: 19 Nov 2014, 10:15
This thing is very neat. Good project matey :2thumbsup:
Daily Lady: 2008 Yamaha YZF R6 - Hannah
Project: 2005 Corsa C 1.4i Club - Charlotte
"Just a 1400 with a loud exhaust and a cone filter" :mrgreen:
Build/Banter thread : viewtopic.php?f=30&t=26607
Ex Daily Lady: 2014 KTM Duke 390 - Lady Katlin (RIP)
Ex Adrenaline Rush: 1997 Suzuki GSX-R 750 SRAD
Ex Daily: 1992 VW Fox 1600
 Post Posted: 19 Nov 2014, 16:04
So so neat! Well done! In total, how much did this all cost you?
Daily: 2005 Corsa Lite
Jason Clifton Photography
 Post Posted: 19 Nov 2014, 18:25
How long did the swap take ?
 Post Posted: 19 Nov 2014, 20:31
I agree. Extremely neat
Good to see another 1.8 16v Corsa C 8)
 Post Posted: 21 Nov 2014, 16:13
Thanks for all the comments guys.
I started on a Thursday around lunch time, and by Saturday afternoon the engine was in with custom mount made. Wanted to try and finish early Saturday morning so i could tow down to have exhaust joined up, missed that deadline and had to wait till following Saturday. I then waited about 2 weeks trying to organize wiring and tuning of the Dicktator, i know was bad planning but didn't expect to get done so quick. I decided to tackle the wiring myself with the help of Carl. So all in all took about 4 weeks with all the delays and bad planning. Estimated cost is around R18 500
 Post Posted: 21 Nov 2014, 16:23
wooooah! nice build dude!
 Post Posted: 24 Nov 2014, 11:36
Another Happy Build! Well done! Please don't forget the figures!
Corsa C Ute Z18XE
"Love Never Fails"
 Post Posted: 03 Dec 2014, 12:48
Hi Thatoneguy
I see from your photos that you using the corsa 3 pin coil .
Are you using it with a dictator module if not how is it wired ?
 Post Posted: 03 Dec 2014, 13:38
i think he is using the 4pin coil
 Post Posted: 03 Dec 2014, 19:06
It is a 4pin coil from the Corsa B, around R670 at Goldwagen if i remember correctly
 Post Posted: 04 Dec 2014, 08:26
Thank you , i will get one :2thumbsup:
 Post Posted: 16 Dec 2014, 09:41
Had the car on the dyno last night, and after Luc worked his magic this was the result.
 Post Posted: 16 Dec 2014, 11:13
Wow nice figures there bud !!
 Post Posted: 04 May 2015, 21:13
Small update:
Been looking for a set of OEM wheels for a while now, and happened to stumble across these a few weeks back
One of the rims had a few bad pavement scratches, forgot to take pics of that one and the repair process. So them decided for some DIY "fun". After quite some time cleaning and then sanding the wheels, the primer went on.
Allowed for some drying time and checked that there was good coverage, then i opted for metallic charcoal by Dulux Duco Spray. This was the end result
Fitted some new Bridgestone MY-01 this weekend as well as had the balancing and alignment done.
Users browsing this forum: No registered users and 12 guests
