Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
 Post subject: Re: Corsa engine rebuild
 Post Posted: 04 Nov 2014, 10:00
Bump updates?
Fear is just words
But driving an Opel is a reality.
 Post Posted: 10 Nov 2014, 08:52
2 weeks later and still waiting for the engine bearings :slapping:
corsa gsi turbo 170kw
 Post Posted: 25 Nov 2014, 11:17
so the bearings has arrived. crank, conrods and pistons are in the block. checked the bearing clearance. everything in spec. head is also finished, new valves and guides and seals.
have done some calculations for the compression ratio. my static cr will be 5.5:1
Bore: 79.5
Stroke: 81.5
Combustion chamber of head: 50cc
Spacer that has been laser cut: 6mm
2 x head gaskets compressed: 0.9mm
Piston dish: -3.5cc
i ended up on 5.62:1 cr. so on low boost 1bar my cr will be 11.24 which will be safe for pump gas and high boost 1.7 bar with water meth 15:1 cr
will start assembly this weekend and will post photos later
 Post Posted: 25 Nov 2014, 13:05
Lekke man
Fear is just words
 Post Posted: 25 Nov 2014, 21:10
OPEL GURU
OPEL GURU
You can't work out compression ratio like you are doing and 5.5:1 static comp is way too low, the car will be dead, you going to need 2 bar boost to make 120kw
Sent from my iPhone using Tapatalk
 Post Posted: 25 Nov 2014, 22:07
Do u have to fit a spacer and 2 head gaskets?? If you bought Low comp pistons I'm sure u don't need all that man.
 Post Posted: 27 Nov 2014, 14:19
Ok sorry. Made an mistake on the head. Its actually 32cc. Which will change my cr to 6.75:1.
How do you calculate cr?
Old setup were like this
Piston dish 8cc and flat on the top off the block
Stroke 81.5mm
Bore 79mm
Gasket diameter 80.2mm
Gasket thickness with spacers 5.4mm
Head combustion chamber 32cc
Then i got 6.9:1
 Post Posted: 27 Nov 2014, 14:24
Wayno when i stripped the engine i didn't know what ill find. But what i found was a gasket, 3x 1.5mm spacers and another gasket.
 Post Posted: 27 Nov 2014, 15:51
OPEL GURU
OPEL GURU
I wouldn't go under 8.5:1 compression
OPEL GURU
OPEL GURU
http://www.csgnetwork.com/compcalc.html
 Post Posted: 27 Nov 2014, 16:11
I used that calculator. The standard pistons had a deeper dish than the 8.5:1 wossner pistons i ordered. Thought it was going to be deeper but it wasn't. So i had to make changes. But i'll see what happens saturday
 Post Posted: 27 Nov 2014, 16:16
There is also a boost compression calculator i used to check how the comppression would change under boost pressures. What is the max compression before detenation starts?
 Post Posted: 27 Nov 2014, 18:26
OPEL GURU
OPEL GURU
You can't work out what your dynamic compression ratio will be using boost without knowing certain things like camshaft specs, valve opening degrees, volumetric efficiency etc, so rather don't waste your time with that, also how are you arriving at your various cc's because stock those engines are over 10:1 compression ?
 Post Posted: 01 Dec 2014, 15:42
few pics
 Post Posted: 01 Dec 2014, 15:45
 Post Posted: 01 Dec 2014, 17:54
Thats a very think compression plate you running. Did you double check you compression ratio again?
 Post Posted: 11 Dec 2014, 01:51
10 days later and still driving lekkker. engine was a success. now its waiting for dyno to see the results
 Post Posted: 11 Dec 2014, 10:58
Cool man! Congrats!
 Post Posted: 14 Dec 2014, 11:14
Lekker om vir jou gister te ontmoet het gemmer!
Pity jy kon nie langer gebly het
Kar klink mooi!
Users browsing this forum: No registered users and 85 guests
