Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3  Next
 Post Posted: 04 Nov 2016, 09:49
I'm Philip from Kathu, Nothern Cape. I bought one of the best cars in SA. It does not look good at first, but there is potential. When you hit OPEL KADETT 200TS on GOOGLE, you will find a pic of this specific car when it was still very pretty.
Regards
Philip Kuhn
0824155625
philipskuhn@gmail.com
Topic moved BACK to "Projects"
 Post Posted: 04 Nov 2016, 10:08
This is the find. The car is good, f28 gearbox, engine is striped with most of the parts already bought. But I will need help finding some cosmetics.
:Help:
I need a 1. std TS airbox
2. that plastic TURBO-intake cover.
Please contact me if anyone knows where I can find this in South Africa.
:Help:
Regards
Philip Kuhn
0824155625
 Post Posted: 04 Nov 2016, 10:53
Damnit
Good luck with the project
Hers:Opel Corsa Chill 1.3
:Germany:
His: Are you kidding me???? When married it states
"What is yours is mine what is MINE is MINE!!!!
:PeaceWhiteFlag:
Ours: Chevrolet Cruze 1.6L
:USA:
 Post Posted: 06 Nov 2016, 14:31
Wow!
 Post Posted: 07 Nov 2016, 07:25
Ou kry sommer 'n by-nes ook!
My Opel maak BUZZ!
Good luck buddy!!
 Post Posted: 11 Nov 2016, 16:16
Ekt hulp nodig. Volgens part no. verkil top-gasket van IS en TS engine? kan iemand vir my se, hoe dit van mekaar verskil. daar is nie TS gasket beskikbaar. Hoe nou gemaak?
Regards
Philip Kuhn
0824155625
 Post Posted: 11 Nov 2016, 16:38
200is is a 8 valve
The ts is a 16valve
You would have to ask for a 94/95 200ie head gasket or from a superboss, monza 200 cd.
:Germany:
:PeaceWhiteFlag:
:USA:
 Post Posted: 14 Nov 2016, 16:10
thank you Ghostc20let.
Im going forward!!
Regards
Philip Kuhn
0824155625
 Post Posted: 15 Nov 2016, 13:15
Wow, great find!
 Post Posted: 16 Nov 2016, 13:16
I'm looking for this back panel to weld in. Please contact me if anybody got something that can help me.
or have a better idea how to fix this.
Regards
Philip Kuhn
0824155625
 Post Posted: 28 Nov 2016, 07:54
Goeie naweek gewees. ekt a engine stand gebou en die motor gehang!! Alles lyk grand!!
Regards
Philip Kuhn
0824155625
 Post Posted: 28 Nov 2016, 07:56
Daarsy. nou kan ek begin bou. Al die machine werk is gedoen.
Regards
Philip Kuhn
0824155625
 Post Posted: 28 Nov 2016, 10:48
Meneer, maak daai engine stand se basis 'n bietjie wyer jong! Dit maak my nervous.
 Post Posted: 28 Nov 2016, 11:37
My kar pas nie eers in my garage, space is baie limmeted. dis hoekom hy soo lyk.
maar dit is baie stewig.
Regards
Philip Kuhn
0824155625
 Post Posted: 30 Nov 2016, 07:28
this Weekend I had help from a expert to do the assembly. I want it done perfectly. this motor must do 300 000k's and more!! Cleaned all the parts first.
Regards
Philip Kuhn
0824155625
 Post Posted: 30 Nov 2016, 12:18
THE GEARBOSS
Regards
Philip Kuhn
0824155625
 Post Posted: 30 Nov 2016, 14:08
Hoendertande
:Germany:
:PeaceWhiteFlag:
:USA:
 Post Posted: 01 Dec 2016, 16:34
Nice project. Are you running standard bore still? Your build is making me miss mine on the road.
 Post Posted: 02 Dec 2016, 07:33
Car has 187 000km's on the clock. Its 0.25 bigger pistons. Car still has allot of work on still!! the body work, worries me allot. In Kathu its not easy to find parts.
Thanx for the interest.
I see your PP. Nice TS!!
Regards
Philip Kuhn
0824155625
 Post Posted: 02 Dec 2016, 07:36
check what I found!! 310x260mm K&N
Regards
Philip Kuhn
0824155625
