philipkuhn
Posted: 02 Dec 2016, 08:02 |
How do one install the motor?
1. Do one ass. the howl motor including exhaust & intake?
2. install the motor with sump into the car, then the top with exhaust and intake?
3 install the howl motor into the car, the ad the exhaust and intake?
witch is best?
_________________ Regards Philip Kuhn 0824155625 philipskuhn@gmail.com
philipkuhn
Posted: 19 Dec 2016, 16:15 |
Ekt die naweek die top en die samp gefitt. Bad news, ek het die cam-caps verloor tussen Bloemfontein-Moorreesburg-Prieska en Kathu.
eenige iemand iets wat rondle?
| Attachments: |
Deano
Posted: 23 Dec 2016, 17:50 |
| Filter & Exhaust |
Joined: 18 Sep 2012, 21:11 Posts: 260 Location: Blackheath (northern suburbs)
if you're on fb search opel 200ts its a group for opel ts owners you may get some spares and parts there
_________________ Fear is just words But driving an Opel is a reality.
philipkuhn
Posted: 25 Apr 2017, 15:33 |
What do you guys say. I have a STD. TS flywheel, its big and heavy. Must I fit a lighter one or use the STD one. I was thinking of keeping the opel STD???
Posted: 25 Apr 2017, 15:44 |
philipkuhn wrote: What do you guys say. I have a STD. TS flywheel, its big and heavy. Must I fit a lighter one or use the STD one. I was thinking of keeping the opel STD??? I would keep the standard one. Helps with cruising.
sterlingesterhuizen
Posted: 25 Apr 2017, 17:27 |
| Cams, ITB's, Headjob, Management |
Joined: 09 Jul 2008, 11:59 Posts: 2991 Location: Kimberley
DJ7 wrote: philipkuhn wrote: What do you guys say. I have a STD. TS flywheel, its big and heavy. Must I fit a lighter one or use the STD one. I was thinking of keeping the opel STD??? I would keep the standard one. Helps with cruising. Agree with dj7 on that
_________________ Hers:Opel Corsa Chill 1.3 His: Are you kidding me???? When married it states "What is yours is mine what is MINE is MINE!!!! Ours: Chevrolet Cruze 1.6L
philipkuhn
Posted: 27 Apr 2017, 13:37 |
sterlingesterhuizen wrote: DJ7 wrote: philipkuhn wrote: What do you guys say. I have a STD. TS flywheel, its big and heavy. Must I fit a lighter one or use the STD one. I was thinking of keeping the opel STD??? I would keep the standard one. Helps with cruising. Agree with dj7 on that Thanx then I will keep the STD one!
philipkuhn
Posted: 18 Sep 2017, 08:47 |
Ek het dam weer gevorder met die Opel motor. Alles kom mooi aanmekaar. Ek is baie tevrede, begin sien nou uit dat die ou start. Al wat ek tot dus ver kort is een injector wat seergekry het met die trek.
| Attachments: |
Klonkie
Posted: 19 Sep 2017, 07:59 |
_________________ 2007 Opel Corsa Utility 1.4 2022 Toyota Corolla HB 1.2T 2024 Toyota C-HR 1.2T
Exes: 2015 Ford Ecosport 1.5 2014 Ford Focus ST 2.0T 2014 Opel Corsa OPC Nürburgring 1.6T 2005 Opel Corsa OPC 1.6T 2008 Volkswagen Golf GTi 2.0T 2005 Ford Territory TX 4.0 2004 Citroën C2 VTR 1.4 2001 Ford Fiesta Zetec-S 1.6 1998 Kia Sportage 2.0 1995 Fiat Uno Beat 1.4
philipkuhn
Posted: 27 Sep 2017, 16:33 |
This weekend, I fitted a new release bearing and wash the engine bay. The coming weekend I want to drain the gearbox oil and fill up with some fresh oil.
Any one knows the amount and type of oil I need? (STD / F28 box)
| Attachments: |
RekordErik
Posted: 27 Sep 2017, 20:01 |
Joined: 02 Jan 2013, 23:09 Posts: 260 Location: Hekelingen, Holland
Hallo Philip, you can check on http://www.opel-infos.de/getriebe/f28.html for the quantity and what kind of oil you need for the F28 gearbox.
_________________ 2001 Corsa C 1.7 DI 3drs - completely standard with very little luxury.
philipkuhn
Posted: 28 Sep 2017, 08:33 |
RekordErik wrote: Hallo Philip, you can check on http://www.opel-infos.de/getriebe/f28.html for the quantity and what kind of oil you need for the F28 gearbox. Good info, Thanx Erik. Maybe some one can direct me with a pic, where to drain and add oil? love working on this car, getting to know her and sort her out bit by bit.
| Attachments: |
RekordErik
Posted: 28 Sep 2017, 20:34 |
Hallo Philip, you can check on http://www.vectraturbo.de/f28.html for draining and filling of the gearbox . If you click on the pictures they will expand so you can see the black arrow(s). Good luck with your project !!
philipkuhn
Posted: 29 Sep 2017, 07:23 |
RekordErik wrote: Hallo Philip, you can check on http://www.vectraturbo.de/f28.html for draining and filling of the gearbox . If you click on the pictures they will expand so you can see the black arrow(s). Good luck with your project !! Thank you Erik. The car in your profile? My friend had a Commodore, just like that, one with the 3l straight 6 motor. Very nice and fast!! what is yours?
| Attachments: |
RekordErik
Posted: 29 Sep 2017, 20:02 |
In the picture of my profile is my previous Opel, a Rekord 2.0 E Berlina S automatic. It was my pride and joy and every now and then I still miss it. My current Opel, Corsa C diesel, is a very good and reliable car and it still drives very well after 360.000 km but it is missing that little bit of "magic" that was present in the Rekord.
philipkuhn
Posted: 03 Oct 2017, 15:16 |
Soo this weekend I did not get anything done. Got cam-caps from Jaco. After fitting the 2 cams, one did not want to turn, after inspection, I found 2 caps where pinching the intake cam. Answer I got, top must be line-bored. Can I only line-bore the caps or must I remove the top again?
philipkuhn
Posted: 05 Oct 2017, 11:34 |
Pinching caps:
| Attachments: |
philipkuhn
Posted: 05 Oct 2017, 11:35 |
These ones seems to be O.K!!
| Attachments: |
philipkuhn
Posted: 05 Oct 2017, 11:40 |
Measured the cam all over. And found 27,95mm. Tolerances seems good, only the 2 caps are a problem. Will see how I will sort this out.
| Attachments: |
philipkuhn
Posted: 06 Oct 2017, 09:49 |
Me again, I need old or drawings of the 2 guide pulleys on the C20LET motor. It is almost 2K for those pulleys. I will make my own, and also, not from plastic.
| Attachments: |
